Author Topic: 1st gear  (Read 2085 times)
Offline Panthera
1st gear
« on: March 27, 2015, 06:30:16 pm »
I am finding it difficult to get my GTi into first gear from neutral - it is fine if I go from 2nd to 1st, even after a long run with the gearbox warm. And also, the gear leaver is rather sloppy in each gear - it feel's like the gearbox has done 200,000 miles and not 72,000. My previous car, a Volvo that had done 105,000, its gearbox was tight as a drum.
I guess there is some sort of linkage/bushes that may have worn?
2007 Blue Graphite Golf GTi
Offline StuF
  • -Given: 31
  • -Receive: 38
Re: 1st gear
« Reply #1 on: March 27, 2015, 06:55:12 pm »
Offline pd9264
Re: 1st gear
« Reply #2 on: March 27, 2015, 08:16:56 pm »
Try resetting your shifter cables. Mine was hard to get into first did this then they were fine.VW 5 speed shifter adjustment for 02J and MQ250 transmissions:
The 6 speed is pretty much the same
« Last Edit: March 27, 2015, 08:20:50 pm by pd9264 »
Offline Panthera
Re: 1st gear
« Reply #3 on: March 28, 2015, 11:52:01 am »
Thank you for the replies and the two options. I think I might go with the later, as at this moment I don't want to modify.
