Author Topic: GTI-Rog's Mk5 GTI "Rejuvenation" Thread (Pic Heavy)  (Read 55945 times)
Offline GTI-Rog
  • -Given: 31
    • facebook.com/FreemanDetailing
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,95428.0.html
Re: GTI-Rog's Mk5 GTI "Rejuvenation" Thread (Pic Heavy)
« Reply #120 on: November 14, 2015, 07:19:21 pm »
Looks great, just go steady as I have caught mine on a few high kerbs when parking! Did you tint your windows or are they factory?
Thanks for the heads up, regarding the front lip  :happy2:
The previous owner put the tints in, I was thinking of removing them as they make my son travel sick :sick: as it feels bit suppressive in the back!
I was pulled over by the police months ago and was told to remove the front tints as they were way too dark... I wasn't bothered as I didn't like them anyway  :grin:
|Ramair Panel Filter|Diamond Black Magic Mk5 Golf GTI OEM+|ED30 rear valance|Monza II 18's|Rev G DV|
Banner 1 by Roger Freeman, on Flickr
|Audi S4 B6 4.2 V8..gone|A3 TFSI Q S line..gone|Gone: Audi A3 3.2 V6 DSG S line|Gone..VW Corrado VR6|
Offline Hannakournikova
« Reply #121 on: November 14, 2015, 09:31:58 pm »
great thread. Looks like a new car now.
Offline jayha11
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97064.0.html
« Reply #122 on: November 15, 2015, 08:15:31 am »
Loving the ed30 splitter addition Rog, all be it slighty envious of your find!
Mk5 GTI > S3 8P > Cupra 300 > Cupra 290 > Mk5 R32
Offline GTI-Rog
  • -Given: 31
« Reply #123 on: November 15, 2015, 07:31:48 pm »
Why thankyou :happy2:
Thanks Jay, I must admit, I was lucky to find it, so I didn't hesitate buying it. I'm very happy with how it's come out too  :smiley:
Offline TheLimla
« Reply #124 on: November 20, 2015, 01:39:48 pm »
Hi Rog, quick question, did you replace the exhaust on your GTI or polish it up?
I've just picked up an 05 DSG in red and whilst in good condition for it's age does need some love like you have given yours.
Offline Pesky jones
« Reply #125 on: November 20, 2015, 03:28:45 pm »
I have tried polishing mine up, ive spent hours on it but can't get it properly shiny. It also looks like some bits have corroded so badly there is section loss.
I use a brillo pad type thing, some wire wool and autosol. If Rog/ anyone can run through their procedure and how long it took them that'd be great
Offline jayha11
« Reply #126 on: November 20, 2015, 03:36:35 pm »
Quickest way to sort the exhaust is to get some new tips (If you look at my project thread I just fitted some to mine)
Offline Pesky jones
« Reply #127 on: November 20, 2015, 03:53:37 pm »
Yeah I saw that, I think rog also comented in the thread.
Where did you get them from?
Offline jayha11
« Reply #128 on: November 20, 2015, 04:06:47 pm »
Just search Audi A4/B8 Exhaust trims. As long as they are 75mm in diameter they will squeeze over the original.
Offline TheLimla
« Reply #129 on: November 20, 2015, 04:16:45 pm »
Good tip, will do! Thanks!
Offline Pesky jones
« Reply #130 on: November 20, 2015, 04:37:20 pm »
Saw some on amazon but it actually lists them as 7.3cm which I take is close enough? I also read some reviews of spot rusting on them, I might leave it a while and see what happens to yours :innocent:
Offline GTI-Rog
  • -Given: 31
« Reply #131 on: November 21, 2015, 11:38:33 am »
Polishing up the exhaust tips, can take quite some time. Mine took repeat polishing to get them to look ok, they certainly aren't perfect.
The way I did mine, the initial time:- using Autosol and a fine grade wirewool (from halfrauds), I gave them a good scrub, using front to back strokes. Then with the Britemax Twins metal polish, repeated with the wire wool, then the same again with a microfibre towel. Then buff to a shine and seal to help protect them.
Any major carbon build up, around the tip edges, I carefully scraped off with a flat head screwdriver. Then I repeated the process, until I was happy as I could be with the finish.
There are many different products on the market, to help get the desired results. Normally, all it takes is a little knowledge, time and effort  :happy2:
The A4 tips Jay used over the top sound like a cool solution, I will check them out and see. Although my look good enough for me at the moment :smiley:
« Last Edit: November 21, 2015, 11:45:43 am by GTI-Rog »
Offline GTI-Rog
  • -Given: 31
« Reply #132 on: November 21, 2015, 11:49:38 am »
These look like the tips Jay has used. @jayha11 maybe able to confirm. :smiley:
http://www.ebay.co.uk/ulk/itm/221576688415
Offline jayha11
« Reply #133 on: November 21, 2015, 11:39:23 pm »
Those are the very ones Rog :-)
Offline Washout
« Reply #134 on: November 22, 2015, 11:36:48 am »
Hey matey car is coming along really well looks very fresh and the monzas really set it off. Thinking about changing my vacuum pump as it weeps, was it an easy job to do and you wouldnt have the new part number handy would you. Cheers
