Author Topic: Amber oil light  (Read 1061 times)
Offline daddykool
Amber oil light
« on: April 02, 2015, 05:47:36 pm »
Hi Guys!
    Wifey came home today with Amber low oil light on!
           Iv'e seen lots of posts with red light on ,but can't find much info on amber situation .
               Oil was a bit low but light keeps coming on although oil is topped up.
    So make this 66 year old boy racers easter  and give me the gen I need and I will send you all big chocolate eggs ,
                         Cheers Ash
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Amber oil light
« Reply #1 on: April 02, 2015, 05:56:21 pm »
Could be pressure / level sensor or blocked pickup pipe.
Best checking the fault codes, and I guess it goes without saying you should avoid using the car, incase there is some failure in the lubrication system
« Last Edit: April 02, 2015, 06:49:52 pm by GrayMK5GTI »
Offline Matto
  • -Receive: 116
Re: Amber oil light
« Reply #2 on: April 02, 2015, 06:43:21 pm »
I had this with mine even though the oil level was fine. I ended up replacing the oil level/temp sensor which is in the sump. You will also find its tied in with the bonnet catch. It won't reset the light if it hasn't seen the bonnet open (assuming you would check the oil while under there) so could possibly be a bonnet catch.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Amber oil light
« Reply #3 on: April 02, 2015, 08:09:48 pm »
sound advice
Offline daddykool
Re: Amber oil light
« Reply #4 on: April 02, 2015, 08:13:00 pm »
Cheers Guys!
              Now I must go out to buy your eggs!!!!!
