Author Topic: Optical Parking Kit  (Read 4984 times)
Offline Lyons
  • -Given: 18
Re: Optical Parking Kit
« Reply #15 on: November 21, 2015, 07:28:52 am »
I got the wires connected in yesterday and the sensors work. Sadly they weren't able to get the display working in the rear as I believe all 8 are needed first.
So now I'm considering doing the fronts too.
Need to have another detailed read through your thread Si as I'd previously ignored any reference to the fronts!
Offline Pashka
« Reply #16 on: November 21, 2015, 07:49:29 am »
Why 8? If your ops module supports 4, when display should work. If your module is 8, but you wired 4, it should only beep loudly. I have only rear installed on mine  with OPS display and everything is working as it should.
« Last Edit: November 21, 2015, 07:52:35 am by Pashka »
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Lyons
  • -Given: 18
« Reply #17 on: November 21, 2015, 08:20:44 am »
Hmm, my module is 4. How did you get it displayed?
Would it depend on exact part number of the module? Maybe other revisions of gateway or conveinience module?
« Last Edit: November 21, 2015, 08:28:55 am by Lyons »
Offline Pashka
« Reply #18 on: November 21, 2015, 10:39:49 am »
Have you coded it? And what's your gateway?
Offline Lyons
  • -Given: 18
« Reply #19 on: November 21, 2015, 03:48:00 pm »
I honestly don't remember, maybe an R or P. Is there a specific 1 that would work? Or is it down to where you code it or another module?
Offline Pashka
« Reply #20 on: November 21, 2015, 10:51:38 pm »
If you had pdc before and went for OPS you have to change the coding, P can gateway is too old aswell. PDC is on the address 76, OPS is on 10, park/steer assist.
Offline SI-R32
  • -Receive: 126
« Reply #21 on: November 21, 2015, 10:54:02 pm »
It's also on a different can network ,  pdc on convenience can,  ops on power train  can
Offline Pashka
« Reply #22 on: November 22, 2015, 10:48:27 am »
The wiring is the main thing aswell, haven't mentioned, because it "must do"  :happy2:
Offline Lyons
  • -Given: 18
« Reply #23 on: November 23, 2015, 05:24:03 am »
I had nothing before.
What's the part umber of your ops module @Pashka ?
« Last Edit: November 25, 2015, 06:41:39 am by Lyons »
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #24 on: December 01, 2015, 11:37:19 pm »
Lyons,
Did you manage to get the optical display working?
In order to get it working, you need to code the module (Park Assist - address 10).
In order to code the optical display setting, you need to get security access firstly to the controller.
Let me know if you need VCDS or anything and I can come help out.  :smiley:
« Last Edit: December 01, 2015, 11:40:45 pm by Rossimac »
Offline Lyons
  • -Given: 18
« Reply #25 on: December 02, 2015, 06:43:32 am »
Not yet, it was left that I have the wrong module I think. You said yours was an 8 sensor one? Do you know the part number?
I assume you got yours working then?
Offline Rossimac
  • -Given: 78
« Reply #26 on: December 02, 2015, 08:11:41 am »
Yeah 8 sensor. Middle section has nothing plugged in.
I know you saw the part number from the other thread, but for continuity purposes for randoms searching the web.....
Were you able to gain access to the controller via VCDS or similar? That bit's the key. When I got mine connected up and before coding, it just had a loud beep when selecting reverse, but nothing worked with regard to the sensors.
Offline Lyons
  • -Given: 18
« Reply #27 on: December 02, 2015, 09:15:08 am »
I didn't do the coding, so I'm not sure.
Sadly this is the only photo I have of mine and when I zoom in I cant make out the part number!
Maybe wouldn't do any harm to meet up and you can try and apply the same coding you have. I don't have VCDS to check the part number and I don't think its visible from where its installed!
Offline Rossimac
  • -Given: 78
« Reply #28 on: December 05, 2015, 07:14:39 pm »
To complete this thread, Lyons' Park Assist module hadn't been coded with optical display selected so while the sensors worked it wasn't being displayed on the RNS.
The fix was to gain Security Access to the controller first and then code the optical display feature.
Just a heads up for anyone finding similar problems.
Offline Lyons
  • -Given: 18
« Reply #29 on: December 05, 2015, 09:55:23 pm »
Yup, cheers for the help yesterday evening Ross- a gent!
