Author Topic: Candy White Golf GTI Ed. 30 - 8th track day at Estoril  (Read 240400 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Candy White Golf GTI Ed. 30 - 5th track day at Estoril
« Reply #480 on: January 22, 2018, 07:15:49 am »
Hmmm...yeah, that's strange, I never knew the existing of those discs, but that is good news.  :smiley:
You'll save a lot of up-sprung weight. Be careful with the bed in, J-hooked are known for generating some vibrations.
Did you install the LSD?
I thought J-hook discs would vibrate less than normal grooved discs.  :confused:
I still have to schedule the LSD installation. Now I have everything at home to get it done. My friend mechanic has to have time available as well. :thinking:
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
« Reply #481 on: January 22, 2018, 07:33:19 am »
Unfortunately this happened to my Reyland J-Hook discs:
I tried to clean them and do the bed in again, but I still had vibrations. After 2 trackdays with no more then 30 laps they cracked. Could be that APs will perform better.
« Last Edit: January 22, 2018, 07:39:51 am by teo_parvu »
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #482 on: January 22, 2018, 08:41:35 pm »
I hope the AP Racing will perform better and not crack after just 30 laps. :surprised:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #483 on: January 22, 2018, 08:44:34 pm »
This is my latest map update. I've changed house, now it's from RPM Engine Power Management, which is based in Italy but has dealers in a few countries. Still a custom tune but from a remote tuner.
It was done with BP Ultimate with 98 octanes. Now I have a lot more torque in the midrange while keeping the same at the top. :smiley:
It had to be done in 5th gear because in 4th the wheels kept spinning. Hence the high drag. Just like my previous map, which was measure in 5th gear as well.
Offline Orama_19
« Reply #484 on: January 22, 2018, 10:56:53 pm »
355cv está brutal!!  :jumpmove: :jumpmove:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #485 on: January 23, 2018, 10:34:27 am »
Não é bem. As temperaturas reais de admissão naquele banco foram um pouco superiores a 50ºC pois tem ventilação fraca para as necessidades. Em estrada o IC anda nos 22-24ºC. Com cálculos de potência de acordo com uma norma qualquer e tendo em conta essa temperatura de admissão de 50ºC, a potência calculada seria superior à medida e não o contrário. :wink:
Foi medido assim para não aparecer um valor de potência calculada ainda mais elevada do que a medida.
« Reply #486 on: January 23, 2018, 12:13:02 pm »
Yay, the Bilsteins are on  :happy2:
You must be enjoying how firm and stable the car is in the corners now?  :smiley:
« Reply #487 on: January 23, 2018, 12:15:05 pm »
Without question  :happy2:
Genuine AP discs are the business.  Discs aren't just discs, it's all in the steel quality  :happy2:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #488 on: January 23, 2018, 10:00:06 pm »
Yeah, the ride is firmer over bigger bumps compared with my old one. I can still make it softer but I'm not sure if I want to.  :laugh: Now the ARB work much less on cornering, for sure. Over small road bumps it's softer, though. I just need to avoid the bigger bumps on the road and all is fine. :signLOL:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #489 on: January 23, 2018, 10:11:08 pm »
I hope I can get the correct size discs from AP. 355 mm should fit but they'd leave a small lip on the outer margin. :confused:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #490 on: January 31, 2018, 01:05:17 am »
I've finally left my car at a new shop to get the LSD fitted. :jumping:
@teo_parvu as you told me, my factory fitted diff has 25 teeth, just like yours. I'm glad I could get the correct version before I had the gearbox opened. Many thanks for your help. :phew:
Here's my old open diff.
More to come. :driver:
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
« Reply #491 on: January 31, 2018, 02:53:30 pm »
 :laugh: :laugh: :laugh: Finally!
Can't wait for a review. Mine is taking longer than expected.  :scared:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #492 on: January 31, 2018, 04:45:51 pm »
Difficult jobs rarely run as fast as we like. Hope that it gets all sorted so you can drive it again! :drinking:
« Reply #493 on: February 02, 2018, 03:02:31 pm »
Looking forward to your diff report  :smiley:
Those crown wheel rivets used to shear off on older Golfs, punching a nice hole in the diff casing.  At least with the diff they get replaced with proper ARP bolts  :happy2:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #494 on: February 02, 2018, 04:10:56 pm »
I didn't know that. Just read that MFactory LSD are made of forged high-nickel-chromium-molybdenum steel. The needed bolts are made of the same steel and are already included in the package. :smiley:
Taken from the MFactory site:
Quote
Specifications
  • Made from imported Japanese SAE 4320 & SAE 9310 Steel
  • Forged, Double Tempered and Super Sub-Zero treated for unsurpassed toughness
  • Advanced Shot Peening technology increases surface hardness
  • Designed to withstand the extreme shock loads of competition-level Drag Racing
  • Advanced gear geometry designed using industry-leading software puts more power to the ground
  • Only the highest quality Brighton-Best Hardware is used
  • Maintenance-free Gears eliminates the need for special fluids & rebuilds associated with plate-type LSDs
  • Lock-free operation ensures no adverse affect to steering response
I can't wait to drive the car again and try the new mod. :driver:
