September 20, 2024, 07:33:09 pm
All Things Mk5
Mk5 General Area
How easy is its to change the rear discs and pads on an Edition 30
Topic: How easy is its to change the rear discs and pads on an Edition 30 (Read 1133 times)
Bish155
Always Involved
-Given: 2
-Receive: 2
April 06, 2015, 07:21:59 pm »
As the the title reads, I have an edition 30 that needs the rear pads and discs changing. How easy is this to do? Thanks
Edition 30, Helix Clutch, pipercross panel filter, pipewerx Downpipe & Sports cat (200 CEL), R-Tech stage 1.5 linear map:314bhp & 321 Ib/ft, Audi S3 front brakes, H&R springs
Bane
Always Involved
-Given: 9
-Receive: 5
"I was born a handsome man and now I'm half a goat
Re: How easy is its to change the rear discs and pads on an Edition 30
Reply #1 on:
April 06, 2015, 08:52:01 pm »
Fairly straightforward as long as you have a caliper wind back tool.
doylebros
Just look at my post count
-Given: 44
-Receive: 309
Reply #2 on:
April 06, 2015, 09:02:11 pm »
As above said but read these comments here
http://forums.vwvortex.com/showthread.php?4469604-MKV-Rear-Brake-Caliper-Carrier-Bolts-Question
because you'll need to remove the carrier bolts and you can hit problems without the correct tooling and vehicle high enough for a breaker bar for the tripple square bolts.
YouTube has videos on the subject to
https://m.youtube.com/watch?v=wt8v4lVZGL0
Bish155
Always Involved
-Given: 2
-Receive: 2
Reply #3 on:
April 06, 2015, 10:25:22 pm »
Appreciate the reply guys
All Things Mk5
Mk5 General Area
