Author Topic: FITTED MFSW CHEAPLY DONE  (Read 18403 times)
Re: FITTED MFSW CHEAPLY DONE
« Reply #15 on: May 03, 2015, 10:46:18 am »
Nice work
Offline andybon
« Reply #16 on: May 12, 2015, 05:01:27 pm »
Going to be doing this soon, so glad I seen this!
I love to do things that people say can't be done just to prove them wrong and to see their faces, I never take "can't do it" as an excuse, the only excuse they are making is they "can't be bothered" to try or take a risk at trying.
(If I get stuck I'll be screaming for help  :laugh:
How hard can it be?
Kam88
« Reply #17 on: May 12, 2015, 05:47:38 pm »
hahah exactly right take your time with the blade as you can't put the foam back  :signLOL: any issues let me know
Offline andybon
« Reply #18 on: May 14, 2015, 05:16:37 pm »
Just out of Intrest, does the buttons clip into anything on the wheel or is it just one screw that holds it in place?
How hard can it be?
Kam88
« Reply #19 on: May 14, 2015, 05:31:48 pm »
if you take some of the foam out on the other side where the little notch is then it will sit in there perfectly and then screw it in  :happy2:
Offline andybon
« Reply #20 on: May 15, 2015, 05:17:00 pm »
All sorted, only casualty was a sliced finger after changing a blunt blade for a sharp one,
How hard can it be?
Kam88
« Reply #21 on: May 15, 2015, 07:21:54 pm »
hahaha i did the same thing  :signLOL:
Offline andybon
« Reply #22 on: May 15, 2015, 09:44:21 pm »
Didn't feel it, only noticed the wet finger and blood everywhere!
Big thanks for the guide!  :congrats:
How hard can it be?
Kam88
« Reply #23 on: May 15, 2015, 09:51:35 pm »
no worries  :happy2:
Offline samiul11
« Reply #24 on: May 24, 2015, 02:15:19 am »
Ive already got highline display so am i right in thinking that i only need the buttons and ch module? And then coding...
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #25 on: May 24, 2015, 09:48:37 am »
Yes, airbag loom and the little black connector at the bottom where the buttons wire and new airbag loom plug into
MPS
« Reply #26 on: August 09, 2015, 02:14:57 pm »
I think I'm going to fabricate some channels for the loom to sit in out of the foam that I've removed. #ghettofix  :signLOL:
MPS
« Reply #27 on: August 09, 2015, 02:23:10 pm »
So if I accidentally removed too much foam would the screws still keep the buttons from wobbling about?
Kam88
« Reply #28 on: August 09, 2015, 08:39:40 pm »
You go pretty much to the petal and go little at a time and test fit also use bit of glue to make it better fit  :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #29 on: August 12, 2015, 04:20:01 pm »
Done this yesterday on an ED30
I won't be doing it again, I think the result with the buttons was not to bad. However the place where the module sits is not to my liking I'm sure it sits deeper on a proper m/f wheel
Cluster and Key coding
Location Great Yarmouth
