Author Topic: FITTED MFSW CHEAPLY DONE  (Read 17591 times)
MPS
Re: FITTED MFSW CHEAPLY DONE
« Reply #30 on: August 19, 2015, 08:12:42 pm »
Done this yesterday on an ED30
I won't be doing it again, I think the result with the buttons was not to bad. However the place where the module sits is not to my liking I'm sure it sits deeper on a proper m/f wheel
Does it really matter if it's covered by the airbag? Obviously as long as it's not chafing?
Kam88
« Reply #31 on: August 19, 2015, 09:32:11 pm »
the way i done mine i am happy with and it is covered by airbag. To be honest if you were to do it for customers maybe doesn't look great in your eyes not sure i can't see a single fault with my one and it saved me lots of money  :signLOL:
MPS
« Reply #32 on: August 19, 2015, 09:35:10 pm »
Kam, any chance you could take a close up photo of the part of the wheel where the buttons go, with the buttons removed?
Sent from my Nexus 5 using Tapatalk
Kam88
« Reply #33 on: August 19, 2015, 09:49:43 pm »
I can take some pics if you pm me your email but to be honest i really don't have time to remove airbag and unscrew the button got lots of things to do
MPS
« Reply #34 on: August 19, 2015, 10:07:15 pm »
Oh yeah sorry I keep forgetting you have to remove airbag! Doh.
MPS
« Reply #35 on: September 03, 2015, 08:42:04 pm »
Done! Foam was a bit of a pain but all sorted now. My mute button doesn't work though? The long coding screen in VCDS flashes up for a second then disappears again? So I can't get to the long coding to change/check it?  :confused:
MPS
« Reply #36 on: September 03, 2015, 08:44:50 pm »
For completeness, the torx screws for the buttons, if you want to get them from VW, are part number: N909 680 01. Approx 83p for 2 from memory.
« Last Edit: September 03, 2015, 09:01:10 pm by MPS »
Kam88
« Reply #37 on: September 03, 2015, 09:10:20 pm »
sounds like another happy customer  :signLOL:
MPS
« Reply #38 on: September 03, 2015, 09:32:02 pm »
Kam, do you know what could be up with my mute button and vagcom?
Kam88
« Reply #39 on: September 03, 2015, 09:57:57 pm »
Have you got genuine vagcom or copy sometimes that can make a difference?
Are you using vw radio ?? or aftermarket ?
I had problems with my vagcom where it did similar thing i left it till next day and tried it and BOOM coding worked that was for my valeo lights and to this day i don't know why it didn't work but got there eventually ?
MPS
« Reply #40 on: September 06, 2015, 11:23:27 am »
I got long coding working. It's an RCD510.
Offline samiul11
« Reply #41 on: September 06, 2015, 05:27:18 pm »
Where did you get the little module from that goes at the bottom of the steering wheel?
And would these buttons do the job?
http://www.ebay.co.uk/itm/Left-Right-MF-Steering-Wheel-Control-Button-For-VW-Jetta-Golf-5-Passat-B6-Tiguan-/231470262645?fits=Plat_Gen%3AMK+V&hash=item35e4b3e975
Kam88
« Reply #42 on: September 06, 2015, 10:39:36 pm »
they will work but you need a little box swell just look for a steering wheel with buttons that is not flat bottom you can pick them up cheap
Offline white91
« Reply #43 on: December 12, 2015, 12:57:35 pm »
I have the buttons, airbag loom and the module they plug into.
Is the only other thing I need the steering wheel control module?
Kam88
« Reply #44 on: December 12, 2015, 08:46:17 pm »
Yes slip ring aswell
