Author Topic: About to buy a RNS510, which extra bits needed?  (Read 1768 times)
Offline edition30jmr
  • ED30
« on: April 07, 2015, 11:46:25 am »
Hi guys as the title says im swapping my rcd300 (or something like that) for a RNS510, I have a March 2007 Eddy.
I know I need a aerial adapter etc the one I am buying is not dav just led and it is VERSION P, will this work without a new canbus in my car if not which versions would work without a new canbus?
 I have a MFSW and Cruise to fit and VW ipod kit already in the glovebox linked up which I would swap over too.
Other than that is it just plug and play? It's had all the latest software and hardware updated etc.
Thanks in advance! :drinking:
Ed30 Beast!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: About to buy a RNS510, which extra bits needed?
« Reply #1 on: April 07, 2015, 12:02:09 pm »
I would check your gateway, if its older than a K version, you need to update it.
You will need a FAKRA adapter for the radio.
When you have a MFSW fitted just make sure thats coded properly so you can go through the menu's (if you have a highline cluster fitted)
  • ED30
« Reply #2 on: April 07, 2015, 12:25:14 pm »
Okay great yeah I have highline I forgot to mention that, il get it checked, what's the easiest way to check manually without using VCDS?
Ed30 Beast!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: April 07, 2015, 12:39:50 pm »
remove the canbus gateway and reading the label is the only other way but its easier to scan using vcds
  • ED30
« Reply #4 on: April 07, 2015, 12:42:25 pm »
Il get a local person who's fitting my intercooler to scan it for me!
One that's advertised said they can change the software so it doesn't cause battery drain! Is this correct or b******t?
Ed30 Beast!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: April 07, 2015, 12:48:24 pm »
In my personal experience, i have downgraded A, B and C, versions (non LED) and installed modified firmware and had no issues.  I had a version D LED once and used the same firmware but I got the battery drain and also my reverse camera stopped working, so just got a new gateway and both issues were fixed.
  • ED30
« Reply #6 on: April 07, 2015, 12:59:37 pm »
Okay il get it checked, where is the canbus located is it behind the cubby hole/ compartment by the drivers controls on the right? And is it easy to change?
Ed30 Beast!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: April 07, 2015, 01:06:30 pm »
it depends on the year. Ive only changed it on a 05 and 55 plate and its always been above the clutch.
according to this guide, its under the wiper arms
http://www.r32oc.com/topic/29242-canbus-gateway-location-removal/
