Author Topic: What else goes wrong?  (Read 859 times)
Offline SiofChester
« on: April 07, 2015, 04:50:51 pm »
So what are the common faults with the Mk5 GTi, I'm on 100K and have just had the "oil pressure" oil pickup problem. I hate unreliable cars so would rather do preventative maintenance... So what else goes wrong, I've done the coil packs, clutch / DMF, oil pickup, timing belt and water pump, cam follower.... What other common problems have folks had?
« Last Edit: April 07, 2015, 04:54:13 pm by SiofChester »
Offline missymckay
Re: What else goes wrong?
« Reply #1 on: April 07, 2015, 04:53:08 pm »
Lots of rust sadly. Found some more last week :confused:
AmD stage 1
Offline Pesky jones
« Reply #2 on: April 07, 2015, 04:54:44 pm »
CV boots apparently - mines just gone.
Offline AndyBrown
« Reply #3 on: April 07, 2015, 05:08:08 pm »
Rear sticking caliper
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #4 on: April 07, 2015, 05:12:19 pm »
I took mine from 50k miles up to 100k miles (MY06) and the only thing that forced me to replace it was the air con compressor and a turbo valve.
Other than that, it was very good although I did look after it well  :innocent:
You can be lucky, or you can be fairly unlucky with some parts - check out the service guides on here to make sure you keep on top of the 'make sure you've replaced this part' sorta' maintenance.
CV boots, cam followers and patches of corrosion (which I had under the wheel arch) are three of the favourites as already mentioned  :happy2:
Pete
