Author Topic: Fitting IC  (Read 6928 times)
Offline Madone
  • -Receive: 27
Fitting IC
« on: April 08, 2015, 01:55:14 pm »
Hi,
At the risk of asking something obvious if I want to fit a IC, sounds like Peron or THS are best. Will these fit without any body mods at all ?, do they come with complete fitting kits ?. Or is the only non body mod solution a twintercooler type setup ?.
Thanks !
Offline xjay1337
  • -Receive: 377
Re: Fitting IC
« Reply #1 on: April 08, 2015, 02:00:51 pm »
What do you mean body mod?
They replace the stock intercooler using factory mounting points..
Offline StuF
  • -Given: 31
  • -Receive: 38
Re: Fitting IC
« Reply #2 on: April 08, 2015, 02:22:58 pm »
Are there any downsides to installing an aftermarket larger capacity intercooler?
I do understand it helps the vehicle cool the incoming air faster and keeps it cooler longer
Is it likely to make the car harder to get upto temp in the cooler months or any other issues?
Not seen a thread that lists the negatives associated with the various modifications we carry out on our vehicles
Offline xjay1337
  • -Receive: 377
Re: Fitting IC
« Reply #3 on: April 08, 2015, 02:25:23 pm »
No, yes, and no.
Offline StuF
  • -Given: 31
  • -Receive: 38
Re: Fitting IC
« Reply #4 on: April 08, 2015, 02:37:07 pm »
No, yes, and no.
 :signLOL:
Cheers - might look at getting one then!
Offline Paradox1
  • -Given: 41
Re: Fitting IC
« Reply #5 on: April 08, 2015, 02:41:32 pm »
Does nobody us the forge style coolers anymore?
twintercooler even
Offline xjay1337
  • -Receive: 377
Re: Fitting IC
« Reply #6 on: April 08, 2015, 03:01:30 pm »
No, yes, and no.
 :signLOL:
 :happy2: :happy2:
pointless getting twintercooler.
the OEM intercooler is a huge sticking point for flow, cooling and power. why have 2 intercoolers when one is better?
Offline mk5-beast-91
  • instagram: subarukid24
Re: Fitting IC
« Reply #7 on: April 08, 2015, 05:30:19 pm »
ive got the airtec big intercooler and twintercooler. totally overkill  :signLOL:
ive had to do no body mods and all fit nicely, just.
my strength lies solely in my tenacity
Offline StuF
  • -Given: 31
  • -Receive: 38
Re: Fitting IC
« Reply #8 on: April 08, 2015, 07:28:36 pm »
Blimey your intake temps must be icy  :drinking:
Re: Fitting IC
« Reply #9 on: April 08, 2015, 07:40:02 pm »
be even cooler once ive fitted my water meth kit lol. hope it doesnt freeze in winter  :signLOL:
Offline Madone
  • -Receive: 27
Re: Fitting IC
« Reply #10 on: April 09, 2015, 09:43:30 am »
I mean do they require and bumper modification etc ?, some coolers make a point to saying 'No need to modify the bumper' indicating some could be required - others don't say anything, potentially indication some cutting required.
Offline xjay1337
  • -Receive: 377
Re: Fitting IC
« Reply #11 on: April 09, 2015, 10:27:20 am »
No, THS, Revo, APR, DsD, Peron don't require any modifications to anything to fit.
The stupid ones that go infront of the A/C rad for that true bad boy look may do.
Offline StuF
  • -Given: 31
  • -Receive: 38
Re: Fitting IC
« Reply #12 on: April 09, 2015, 12:23:38 pm »
Do these aftermarket intercoolers come complete with all the piperwork too?
Sounds like it might be a straightforward job after all with no visible signs of it being installed - which is something that appeals to me  :smiley:
Offline Paradox1
  • -Given: 41
Re: Fitting IC
« Reply #13 on: April 09, 2015, 12:24:06 pm »
i was planning on a forge style cooler as its seems eaiser to fit and personally i liek the look of the subtle cooler through the vents
Offline Madone
  • -Receive: 27
Re: Fitting IC
« Reply #14 on: April 09, 2015, 01:13:55 pm »
Thanks, that's what I meant. I want one that looks as discrete as possible so black is a likely choice. I know Airtec are popular in Ford circles. Any opinion on these ?, hard is a cooler to fit ?, could it be done on the drive or is a ramp etc recommended ?
