Author Topic: DSG Launch control  (Read 25487 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=pl4pun8ihns6vq1a5ngf0kle49&/topic,90967.msg917089.html#msg917089
Re: DSG Launch control
« Reply #60 on: May 26, 2015, 05:42:00 pm »
Like @ROH ECHT said "It doesn't apply full force on the clutch packā€¦it allows slippage at launch."
If i don't have LC i can still release the brake at 2600rpm but i doubt its good for the gearbox.
05 | Tornado Red | DSG
Offline usmangti
« Reply #61 on: May 26, 2015, 07:01:29 pm »
@dazza so are you saying there are two possibilities here? I thought revving at 2.5k with esp off etc is the LC? In park and neutral you can Rev the engine but in D/S or manual mode it won't Rev freely anyway.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #62 on: May 26, 2015, 07:06:30 pm »
I have no idea mate. TBH i think it should rev more than 2600 when you have LC. Hence i think i don't have it.
Offline HughOR
« Reply #63 on: September 13, 2015, 08:41:11 pm »
When using launch control on mine, when I let off the brake, there is a slight delay before anything happens, any idea what's causing this? It sits at just under 3k
Offline Pesky jones
« Reply #64 on: September 13, 2015, 10:30:14 pm »
Same!
Offline petesimcock
« Reply #65 on: September 14, 2015, 09:54:32 am »
I've found my launch control absolutely useless since my remap :/
Offline Vagperformance
« Reply #66 on: September 14, 2015, 01:29:27 pm »
We do the APR DSG remaps and it makes quite a difference in driving and with launch control  :grin:
Offline HughOR
« Reply #67 on: September 14, 2015, 11:45:53 pm »
I'm going to look into getting my gearbox mapped alright... Don't know much about it though
Offline dan930
  • -Receive: 56
« Reply #68 on: September 15, 2015, 12:42:14 am »
Dsg remap will give you faster shifts,raise the Redline a bit & higher revs for LC
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline HughOR
« Reply #69 on: September 15, 2015, 10:06:58 am »
Thanks. Will it do anything for the delay I have when I take my foot off the brake pedal when using LC??
Offline dan930
  • -Receive: 56
« Reply #70 on: September 15, 2015, 11:40:09 am »
What delay?power should be instant when u let off the brake
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #71 on: September 15, 2015, 12:04:49 pm »
I think some people with older cars are trying to launch when they don't have launch control.
Offline john87
  • -Receive: 53
« Reply #72 on: September 15, 2015, 12:07:41 pm »
My friends' A3 TDI S-Line doesn't have launch control.. if he attempts the procedure, he just hears horrible noise of the clutch trying to transfer power to a stationary car.. accompanied by that signature burning clutch smell  :confused:
so if you don't have it, you're just gonna burn out your clutch if you attempt it.. or so it would seem!
Offline Pesky jones
« Reply #73 on: September 15, 2015, 01:49:09 pm »
I have a slight delay when I let off the brake, but then it seems like the power comes. I'm not sure if I would get this power if I just went from no revs to flat out (obviously not flat out to the point where the wheels just spin) however...
mine revs to just under 3000 and there is no horrible clutch noise or smell, 05 plate
Offline dronners
« Reply #74 on: September 15, 2015, 02:13:27 pm »
my gearbox also has a momentary delay from removing your foot off the brake whilst it engages the clutch say like less than a second but defiantly noticeable  i think thats normal  its not gonna be 100% instant
