Author Topic: DSG Launch control  (Read 25494 times)
Offline Morgen
  • 2008 DSG Edition 30
Re: DSG Launch control
« Reply #75 on: September 16, 2015, 04:03:14 pm »
I also get the slight delay.. But I can definitely tell a difference when launching! Sits at 3k for me  :smiley:
My car is also slightly jerky in first when setting off but smooth in every other gear and reverse. Does this sound like an issue to anybody?
Offline Jarre
« Reply #76 on: September 17, 2015, 03:29:04 pm »
When launching or with normal driving? Isn't jerky when setting off one of the first signs of the mechatronics unit going?
Candy White ED30 :)
Offline AndyBrown
« Reply #77 on: September 23, 2015, 12:35:35 pm »
Could be youre mechatronic unit that you know, find someone with vcds to rest the box see if that helps
Offline Morgen
« Reply #78 on: September 23, 2015, 12:36:30 pm »
The unit was replaced under warranty in 2011.. So if it's going again then that's annoying as I've had it serviced as recommended etc! Stupid thing.
Offline Pesky jones
« Reply #79 on: September 23, 2015, 01:24:18 pm »
Not 100% sure it is a sign of failing mechatronics unit - although seeing as mine does it as well that could be me hoping!
It only does it on a cold start - so pretty much in the morning each day. Reverse works fine though and I've heard that can be affected.
I've also heard DSG reset can help it - although im not sure what exactly a dsg reset is!
Offline Morgen
« Reply #80 on: September 23, 2015, 04:49:52 pm »
my boyfriend has access to vagcom so may get him to look into it for me  :smiley:
If it's no better after that I'll just have a wee cry instead
Offline Pesky jones
« Reply #81 on: September 23, 2015, 04:54:01 pm »
Let me know the result please!
Offline Morgen
« Reply #82 on: September 24, 2015, 02:08:14 pm »
forgot to mention it to him! hopefully he has the correct cable for mines as his is a mk4.. I'll try get it done tonight or Friday & let ya know! :happy2:
Offline Pesky jones
« Reply #83 on: September 25, 2015, 03:44:46 pm »
@Morgen
I've just seen from another post that a good test for a failing mechatronics unit is:
With the engine running, go straight from neutral to drive and see if it sets off without any hesitation or a distinctive knocking.
Same from park to drive.
I’ll try mine later but I don’t seem to remember mine doing this, hopefully yours doesn’t either. Maybe we just need this “DSG reset” I’ve heard about.
Offline Scoobykiller
« Reply #84 on: September 27, 2015, 11:07:13 pm »
Tried this on my 07 today. Revs would just sit on 1500 and its like its not even revving. Let go of brake and nothing. Lol
Offline HughOR
« Reply #85 on: September 30, 2015, 06:58:38 am »
You're not activating launch control so... Check out video in post #22 on this thread
Offline th3_f15t
  • -Receive: 183
« Reply #86 on: October 04, 2015, 02:22:23 pm »
Well, my launch control isn't active. :sad1:
Tried in manual, it just revved to 1200RPM then took about a second to engage and go. In S mode I can freely rev until I release the brake and it still takes about a second to engage and launch away. With a 4motion system its really quite tame under full load, but I definitely need a remap and active launch control for my DSG 'box now.
Off to the tuners I go...
Offline Kai96
« Reply #87 on: August 10, 2016, 06:25:24 pm »
Silly question but does the handbrake have to be up or down with launch control ? Mine is a 2008 model so I'm hoping I have LC
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #88 on: August 10, 2016, 07:25:12 pm »
Down. I had the DSG mapped before even trying to use the LC...  :signLOL:
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #89 on: August 10, 2016, 08:12:58 pm »
LC pointless on a front wheel drive car as you have to turn traction control off to use it = loads of wheel spin.
Sounds good though.
« Last Edit: August 11, 2016, 06:07:21 am by slix »
