Author Topic: Deano Gti search  (Read 55192 times)
Offline Martk19871
  • Va Va Voom
Re: Deano Black Golf GTI
« Reply #120 on: May 27, 2016, 07:26:18 pm »
Looking really mean mate! If it was a different month I'd jump on that Milltek. Out of curiosity, what did you pay for the exhaust to be fitted? I've started using a VW specialist in Bristol but have outright said they dont fit parts unless bought from them  :chicken:
Offline Deano45
« Reply #121 on: May 27, 2016, 07:36:04 pm »
Hello buddy ... Not the cheapest mod in the world  but I always wanted to do it ....only paid around £40 to get it fitted on top of the cost of the exhaust
Offline Ruggy
« Reply #122 on: June 02, 2016, 12:50:44 pm »
Are you able to post the exhaust?  And do you still have the rear bumper/valance?
Offline snowley
« Reply #123 on: June 02, 2016, 01:18:52 pm »
Looks great with the new valance and exhaust, makes a real difference.
Offline Deano45
« Reply #124 on: June 02, 2016, 08:51:12 pm »
Cheers ....snowley yeah gives the rear a bit more presence ....
Offline bad devotions
  • -Given: 19
« Reply #125 on: June 04, 2016, 09:31:49 pm »
Love this car! I have a black 56 plate GTI and I'm definitely nicking a few ideas from here :)
Offline Deano45
« Reply #126 on: June 11, 2016, 06:20:13 pm »
Cheers for the comments ....bad d ...Their is loads of inspiration on this forum....
Offline Deano45
« Reply #127 on: June 11, 2016, 06:40:14 pm »
Hi everyone
                     just a small update as i do ...decided to get a bit of maintenance done..first of all decided to get the sump off   and get the oil pick up pipe inspected and cleaned ....on inspection of the oil pick up pipe is was clean..But glad i had it looked at for peace of mind though...so replaced with fresh castrol 5w-40
Also ordered another set of 10mm H&R 10mm spacers for the rear ...it looks right now front and Back...
IMG_0596 by DEAN JONES, on Flickr
IMG_0603 by DEAN JONES, on Flickr
IMG_0582 by DEAN JONES, on Flickr
Offline Rippers
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,105772.0.html
« Reply #128 on: June 24, 2016, 02:30:58 pm »
Car is looking mint.
Do you know have 10mm all round on the spacers?
Offline Deano45
« Reply #129 on: June 24, 2016, 03:52:43 pm »
Hi Rippers........cheers for the comments..yeah I now have 10mm h&R spacers front and rear. It looked a bit odd with just front spacers so now is looks right front to back..
Offline Craig Stanley
« Reply #130 on: June 24, 2016, 07:07:43 pm »
For what reason would you put spacers on. Just curious.
Sent from my SM-N910F using Tapatalk
Offline Deano45
« Reply #131 on: June 24, 2016, 07:54:28 pm »
HI...had to put spacers on the front to clear the R32 Brakes....it just made sense putting them on the back to make everything look right.....
Offline Rippers
  • -Receive: 20
« Reply #132 on: June 30, 2016, 01:22:23 pm »
No issues with handling? I've heard this can have a negative effect on the handling when you change the track.
Where did you get them from?
I'm saving for a remap but not done a mod for a while so i'm getting itchy feet!
Offline Deano45
« Reply #133 on: June 30, 2016, 08:52:02 pm »
Hi rippers.....no issues with handling at all you can't tell they are their...I have run spacers on all my cars over the past 5 years and have had no problems ...with a wider wheel track and a good suspension setup your onto a winner....also looks so much better than stock..
I brought these from PSI TUNING great company...
as for the remap I guess your going to r-tech?
Offline Rippers
  • -Receive: 20
« Reply #134 on: June 30, 2016, 11:08:59 pm »
That's good to know, I'll check out PSI. I'm running H&Rs on OEM shocks at the moment. Hopefully that will be good enough.
As for the remap I'm lucky being based in Essex I have AMD, Revo and a host of local smaller tuning garages that can produce some good results. I'd like to get as close to 300bhp on a KO3 as I can. RS4 fuel valve, induction kit (installed), miltek or BCS power valve exhuast all contributing.
I've brought mine back from the brink, but there's always more
