September 20, 2024, 03:58:53 am
All Things Mk5
Mk5 General Area
True alloy size
Topic: True alloy size (Read 1549 times)
Pesky jones
Just look at my post count
-Given: 2
-Receive: 19
True alloy size
April 09, 2015, 06:21:18 pm »
Wasn't sure what size my alloys were so decided to measure them...between the extents of the alloy (the true diameter of alloy) measured 495mm. When it says 17" or 18" does it mean 18" from one side of the alloy to the other? Or is it something weird. 18" in mm is 457.2
Pesky jones
-Given: 2
-Receive: 19
Re: True alloy size
Reply #1 on:
April 10, 2015, 11:20:29 am »
Bump
Carpy25
Always Involved
-Given: 11
-Receive: 40
Re: True alloy size
Reply #2 on:
April 10, 2015, 01:28:55 pm »
You measured lip to lip the outer edges but the Tyre sits below the lip so your size is 38 mm or so over 18 inch that's a 20 mm lip which sounds about right
Rob
Pesky jones
-Given: 2
-Receive: 19
Re: True alloy size
Reply #3 on:
April 10, 2015, 01:44:33 pm »
Cheers, I think its a bit weird that the visible alloy is 19", but there called 18"!
th3_f15t
-Given: 66
-Receive: 183
My Ride:
Re: True alloy size
Reply #4 on:
April 10, 2015, 02:42:25 pm »
Quote from: Peskyjones on April 10, 2015, 01:44:33 pm
Ours is to admire, not to question the logic.
I'm sure if you measured enough alloys in this same way the variation of "on show" diameter will vary massively. Good little post though, like being enlightened on things like this.
Pesky jones
-Given: 2
-Receive: 19
Re: True alloy size
Reply #5 on:
April 10, 2015, 02:50:35 pm »
CRUEL. Thought I had 19" monzas!... Even if they are in a terrible state. Won't be for long though...refurb planned
th3_f15t
-Given: 66
-Receive: 183
My Ride:
Re: True alloy size
Reply #6 on:
April 10, 2015, 02:59:17 pm »
I'm sure you could find 19" replica alloys, but the profile would be so low the ride would be trashed!
Pesky jones
-Given: 2
-Receive: 19
Re: True alloy size
Reply #7 on:
April 10, 2015, 03:07:30 pm »
I don't want them, I just thought I already had them! happy that I've got 18s opposed to 17s however!
Rob.
Always Involved
-Given: 7
-Receive: 22
Re: True alloy size
Reply #8 on:
April 12, 2015, 08:41:37 am »
Your tyre size will be bit of a giveaway
@Peskyjones
Pesky jones
-Given: 2
-Receive: 19
Re: True alloy size
Reply #9 on:
April 12, 2015, 11:00:53 pm »
Huh?
Rob.
Always Involved
-Given: 7
-Receive: 22
Re: True alloy size
Reply #10 on:
April 13, 2015, 08:52:30 pm »
If the number on your tyre side wall reads 225/40/18, then you have 18" wheels.
All Things Mk5
Mk5 General Area
True alloy size
