Author Topic: Canbus Gateway Part Numbers  (Read 1385 times)
nickwj
« on: April 10, 2015, 02:44:55 pm »
Hi All,
I have just bought an RCD310 head unit for my 2007 Mk5 GTi and am searching for a replacement Canbus gateway of the right revision so I don't get the battery drain. Just got a couple of questions though if anyone can help...
1. 1K0907530 - This comes up as fitting all sorts of VAG cars - Skodas, Audis, other VWs, etc. But does it matter what car it has come out of or is it exactly the same so long as it has that part number?
2. I am looking for one of revision L or later - is this correct or does it have to be revision L? I have seen all sorts... L, Q, AD - I presume anything later than L will do the job?
Many thanks!
Offline olsen-72
  • -Receive: 21
  • Redditch
Re: Canbus Gateway Part Numbers
« Reply #1 on: April 10, 2015, 04:28:43 pm »
L or higher
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
nickwj
« Reply #2 on: April 12, 2015, 08:54:42 pm »
Thanks Olsen. Do you know if it matters what car the gateway comes out of, or are they all the same under that part number?
