Author Topic: better sound?  (Read 2886 times)
Offline The666
better sound?
« on: April 11, 2015, 04:01:03 am »
any way to get good sound out of the engine and exhaust without spending too much £. Right now mine is completely stock will be getting a remap soon it's a dsg. was thinking dump valves and resonator delete? don't wish to spend more than £200 what are my options if sound will be dramatically improved maybe £300.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: better sound?
« Reply #1 on: April 11, 2015, 04:54:01 am »
Cheapest way is to remove the pre cat
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: better sound?
« Reply #2 on: April 11, 2015, 09:22:04 am »
This ^^
Don't do a dump valve, the TFSI is designed to have boost recirculated. If you want whooshing & hissing noises buy an EVOMS intake for £285
Resonator delete will drone and soon drive you up the wall  :signLOL:
Offline lady_gti
Re: better sound?
« Reply #3 on: April 11, 2015, 10:05:27 am »
If you do choose to remove the resonator I would do the pre cat delete as well it gets rid of most of the drone and has a very good sound for a stock exhaust as I have done the same and cost me £50  :happy2:
Reflex silver GTI, revo intake, eurojet dogbone mount and insert, colour coded rear bumper, projector headlights, revo stage 1, precat delete, cente resonator delete, R8 coilpacks, eibach sportlines, depo projectors, 4300k hid kit... Not finished yet
dansmith180
Re: better sound?
« Reply #4 on: April 11, 2015, 11:13:10 am »
Try finding a second hand evoms/ revo/ itg intake for £200 - £300 and remove the precat on your driveway, that'll give you some good noise and more power. Otherwise wait for a cheap cat-back to come up for sale.
Offline Neil 54
Re: better sound?
« Reply #5 on: April 11, 2015, 11:21:41 am »
Another vote for pre cat removal cheap better exhaust note and better flowing exhaust win win
Offline The666
Re: better sound?
« Reply #6 on: April 11, 2015, 07:40:18 pm »
thanks for the replies. OK where can I get pre cat removed and also should I get it done before remap or after or it wont make a difference?
Offline The666
Re: better sound?
« Reply #7 on: May 04, 2015, 04:59:17 pm »
still haven't been able to find a garage that will do a pre cat removal. Been calling r-tech but not getting any replies. Has any one got a pre cat removed from a garage in London if so care to share their details or pm their number
Offline mdmay
  • -Given: 38
Re: better sound?
« Reply #8 on: May 04, 2015, 05:08:33 pm »
do it yourself it is is easy undo 4 bolts, remove both Lambda, undo the connecting band to the back box, remove exhaust brace,  strike the catalyst with a hammer and chisel. empty out broken catalyst. replace on car drive and smile
Regards,
Mike
Offline The666
Re: better sound?
« Reply #9 on: May 04, 2015, 05:10:44 pm »
forgot to mention I will not be able to attempt this myself don't have the tools or the knowledge to that's why I have been looking for a garage to do it for me or if any of you guys have done it yourself and live close or in London then maybe we can work something out ? :)
Offline mdmay
  • -Given: 38
Re: better sound?
« Reply #10 on: May 04, 2015, 05:17:15 pm »
where in london are you may be able to go in to somewhere like Formula one tyre and exhaust center and ask them to remove that section of the exhaust and then reattach after you give it a clout
Regards,
Mike
Offline The666
Re: better sound?
« Reply #11 on: May 04, 2015, 05:23:44 pm »
Hackney
Offline mdmay
  • -Given: 38
Re: better sound?
« Reply #12 on: May 04, 2015, 05:51:06 pm »
In that case there is a formula one in Woodford who are never busy and am sure will do it.
Regards,
Mike
Offline patpong_pete
Re: better sound?
« Reply #13 on: May 04, 2015, 11:36:22 pm »
mdmay do you know what they might charge ?
after smashing it out would you use wire wool etc....
thanks in advance for help and reply
Offline Spankiee
  • -Receive: 20
Re: better sound?
« Reply #14 on: May 05, 2015, 09:16:11 am »
Wire wool ? What for?
Just smash it / drill it out if you have a long drill bit then empty out all the pieces
candy white edition 30
