Author Topic: 3M Headlight Restore.  (Read 3082 times)
Alfalfa91
« on: April 13, 2015, 09:41:43 am »
Yesterday I used the 3M headlight restore kit I bought from eBay for £16 odd and what a result I got.
People say that it takes about 2 hours to do but because I started on the finest pads it took me about an hour to do.
Very easy to use and was a lot quicker then I expected.
This is the kit i bought and it comes with 3-4 different grades of sandpaper pads but i just went straight the finest one and started.
You get 2 pads per headlight so after the 2 pads where used you move onto the rubbing paste and the buffing pad you get with the kit, after a while your headlight will look like this.
I would recommend to do it with your bonnet shut or to remove your headlights and also don't ware good jeans! haha
But when you are happy with it I went over it one last time with some Autoglym polish just got the final finish and it turned out great!
I would highly recomend this kit and all you need is a drill and something to spray water on the headlights as you go and you should be sorted!  :happy2:
If anyone has any questions about this just give me a shout.
« Last Edit: April 13, 2015, 09:45:54 am by Alfalfa91 »
Offline xjay1337
  • -Receive: 377
Re: 3M Headlight Restore.
« Reply #1 on: April 13, 2015, 09:48:49 am »
Lol, um wow.
Nice transformation but what a mess you've made! We do quite a few headlights, especially on Mk5's - we do them with the bonnet up as it's just another edge you're not going to accidentally damage - and never make that amount of mess, haha!
Hope you have put some decent wax on the headlights as well - they will soon return to being yellowed and faded if not, as you've removed the remaining protective UV layer by sanding/polishing!
Alfalfa91
« Reply #2 on: April 13, 2015, 10:04:53 am »
Lol, um wow.
Yeah I went a bit canny with the paste haha but was a good excuse to give the engine bay a clean up lol
Yeah I used some expensive Autoglym wax but will was planning on giving them a going over whenever wax the car just to give it that nice finish.
I think it came out not to bad for the first time doing something like that.
Offline GTIEagles
« Reply #3 on: April 13, 2015, 11:13:27 am »
Fantastic, that's convinced me to get the same kit. My headlights look identical to yours making the whole front end of the car look old and worn!
Offline akbarirfan
  • -Given: 81
« Reply #4 on: April 13, 2015, 11:17:08 am »
Nice work!
Did you use a battery operated drill or corded?
Also @xjay1337 which wax would you recommend?
Alfalfa91
« Reply #5 on: April 13, 2015, 12:00:40 pm »
Nice work!
I used a battery for one side then it died as I started the other then used the mains drill. Wish I started with it cause I was done a lot faster
Offline xjay1337
  • -Receive: 377
« Reply #6 on: April 13, 2015, 12:41:44 pm »
Nice work!
We always use Carpro DLUX.
Anything with high UV protection qualities would be good.
Offline GTI8v
« Reply #7 on: April 14, 2015, 09:02:50 pm »
I've got the same kit waiting for the weekend, hope I don't make as much mess under the bonnet as you  :signLOL:
Think I need to sort a corded drill though
Alfalfa91
« Reply #8 on: April 14, 2015, 09:44:43 pm »
Nice one, should work a treat and yeah hopefully! Haha
