Author Topic: abs fault again and again!  (Read 1000 times)
Offline cander83
« on: April 14, 2015, 08:34:25 pm »
Has anyone ever had problems with the wiring going to the wheel speed sensor .getting sick Fed up fixing it . Anyone had similar problems
Offline chigmuss
Re: abs fault again and again!
« Reply #1 on: April 15, 2015, 07:54:28 pm »
What kinda faults are you getting? Have you scanned for faults. The rear abs sensors corroding is a common issue and usually remedied by changing the appropriate bearing. A good indie should charge only couple hours tops plus the bearing cost. I'm lead to believe the abs pumps are not necessarily the first component to throw up a fault, just if you're worrying its a pump replacement job. Fingers crossed it the lesser of the evils for you.
