Author Topic: Fitted my CH control module today *help*  (Read 958 times)
Offline MJGib
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,85702
« on: April 14, 2015, 08:59:53 pm »
Fitted my CH control module today... Just need to know what I have to do now because Ive got a orange steering wheel light on & intermittent power steering...
Instruct me please, only if you know 100%!
MK5 Golf GTI: K04 converted stage 2+ (I don't own this car no more)
Insta - gibs94_
Offline v4rley
  • -Receive: 104
Re: Fitted my CH control module today *help*
« Reply #1 on: April 14, 2015, 09:15:56 pm »
Check Ross-tech: http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist#Adaptation
Quoted from above link pretty sure it's:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left.
Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
System voltage at leas
Also
(Engine still running)
Center steering wheel (±10°) and hold it centered for 5 seconds.
Turn steering wheel completely to the left and hold it there for 10 seconds.
Turn steering wheel completely to the right and hold it there for 10 seconds.
Center steering wheel (±10°).
Switch OFF engine and ignition.
Switch ON ignition.
Wait 5 seconds.
Steering Assist Warning Lamp should turn OFF. If it doesn't, perform a short test drive.
Kam88
« Reply #2 on: April 14, 2015, 09:54:51 pm »
need to plug in vag com toget everything cleared all the codes and code the new module to the car had the same problem abut 2 weeks ago when i fitted my mfsw and highland
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: April 15, 2015, 07:42:15 am »
Try taking it for a short test drive as well with a few full lock turns in an empty area like a car park.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #4 on: April 15, 2015, 05:38:19 pm »
Start the vehicle.
Also
Switch ON ignition.
Wait 5 seconds.
^^^^^ This
steering angle sensor needs to be adapted. This happened to me, PITA. Take your time and follow the instructions, took 3 or 4 times before mine sorted it's self out
Offline MJGib
  • -Given: 22
« Reply #5 on: April 16, 2015, 12:18:05 am »
Yeah still not doing it, did try 3 times today
Insta - gibs94_
Offline MJGib
  • -Given: 22
« Reply #6 on: April 16, 2015, 12:18:36 am »
Btw thanks for the input guys
Insta - gibs94_
