Author Topic: RCD510 content removal?  (Read 2427 times)
Offline jimmy-s3
« on: April 15, 2015, 09:58:15 am »
I'm struggling to work out how to remove music that is stored on my RCD510 head unit. I there a simple way of doing this?
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: RCD510 content removal?
« Reply #1 on: April 15, 2015, 10:40:52 am »
That model doesn't have any storage?
Offline paulw123
  • -Receive: 47
« Reply #2 on: April 15, 2015, 04:09:05 pm »
RNS 510 has HDD storeage
RCD 510 does not
Offline jimmy-s3
« Reply #3 on: April 16, 2015, 07:14:56 pm »
Sorry, yeah it's an RNS 510....
Offline jimmy-s3
Re: RNS510 content removal?
« Reply #4 on: April 21, 2015, 07:32:44 pm »
Anyone know how????
It's comes up with " do you really what to delete this file".
When I select Yes is then says "the active audio file cannot be deleted".
It's the only song left on the HDD...
Offline jimmy-s3
« Reply #5 on: April 25, 2015, 06:40:23 pm »
I guess I've finally found a question about the MK5 that no one knows the answer to..?
Offline AndyBrown
« Reply #6 on: April 25, 2015, 06:51:30 pm »
Maybe the files been used on the player?
Try adding another song and playing it then delete that one.
Just a total guess but might be worth a try
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=0j6tv3tden54ic1n5jiulfq0fi&/topic,90967.msg917089.html#msg917089
« Reply #7 on: April 25, 2015, 06:58:14 pm »
So you managed to delete other files?
Try deleting the entire folder that the file is in.
05 | Tornado Red | DSG
Offline jimmy-s3
« Reply #8 on: April 25, 2015, 09:08:45 pm »
I can't seem to add any other tracks/files to the HDD. Is there a certain way of doing this?
It says there is 18GB free meaning fully empty.
Offline simonp
  • -Receive: 38
« Reply #9 on: April 28, 2015, 09:03:53 am »
Is there not a format HDD option, or return to factory settings maybe?
Offline Jasons4s
« Reply #10 on: April 28, 2015, 02:56:19 pm »
Hi there,
Its beacause the file is still open as its the last one "media" played and it doesn't really stop, just pauses.
Put an mp3 on an SD card and play that one, then pause\stop and you can delete the file\folder off the HDD.
Then you can pop the SD card out.
That worked for me!
Good luck,
Jason.
