Author Topic: Can a BHZ engine be used in replacement of a CDL engine  (Read 1876 times)
Offline vag12
« on: April 15, 2015, 01:00:16 pm »
Just need some information regarding engine swaps, my mates golf R with CDL engine has starved of oil and been looking for a replacement, Only one he has found is a BHZ engine. He is running 370bhp and 380lbs of torque before the engine failed, so needs info regarding the BHZ block will be fine for a straight replacement without the need to adjust the map or anything?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Can a BHZ engine be used in replacement of a CDL engine
« Reply #1 on: April 15, 2015, 01:43:36 pm »
Engine will bolt in fine, inlet camshaft is different so map will require tweaking
Offline vag12
« Reply #2 on: April 15, 2015, 01:50:14 pm »
so definately will need tweaking? I thought the BHZ and CDL is almost identical
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: April 15, 2015, 04:47:40 pm »
CDL has a better inlet cam lobe for the HPFP providing more fuel pressure  - who mapped it? All tuners will have an equivalent map for the BHZ.
Offline vag12
« Reply #4 on: April 15, 2015, 07:14:26 pm »
Was mapped by r tech but they don't have a slot for weeks now so just really wanted to know will it be safe as it is since the bhz can handle the same amount of power usually
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #5 on: April 16, 2015, 07:21:32 am »
Think you better speak to Niki  :happy2:
