Author Topic: Audi TTRS Intank fuel pump wiring mod  (Read 6880 times)
Offline aarondsg
« on: April 16, 2015, 12:58:11 pm »
Hi does anyone have a link or any information to help me complete this wiring mod ?
I heard because of the starting amps on a ttrs in tank pump it overheats the fuel controller and causes fuel cut one you go throught the gears at wot.
Apparently there is a wiring mod that will prevent this .
any help please ?
R-Tech Power Stage 2+ Edition 30 (LC9Z)
Offline Pikey Motorsports
Re: Audi TTRS Intank fuel pump wiring mod
« Reply #1 on: April 16, 2015, 10:12:15 pm »
Speak to TSR they figured out how to bypass it on mine
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline vRSAlex
  • -Receive: 253
« Reply #2 on: April 17, 2015, 07:56:25 am »
I've not once had an issue on the vRS.
Follow AKS tuning on Facebook
Offline aarondsg
« Reply #3 on: April 17, 2015, 08:44:07 pm »
should i just fit it and hope for the best ? @vRSAlex
Niki recons i will get fuel cut around 140mph  :ashamed:
Its still in box unused was gonna get it refunded
Offline basman
« Reply #4 on: April 18, 2015, 12:57:00 am »
 :jumping: :jumping: if you hear how id like to know also as mine if limping, would cts already have this built in??
« Reply #5 on: April 18, 2015, 01:31:58 am »
Most are ok with k04 its when u work them hard the more my boost went up the worse it got
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline aarondsg
« Reply #6 on: April 18, 2015, 03:14:26 am »
@basman
Dont be silly.
They need the feed bypassed for when on wot somehow.
You would have to run a seperate feed.
The ttrs pump draws over double the current over heating the fuel control unit
Offline aarondsg
« Reply #7 on: April 18, 2015, 03:16:36 am »
@Pikey Motorsports ok thanks
i may try it then .
Just dont wanna be out boosting and get fuel cut as people dont tend to buy excuses well  :signLOL:
All i want is a wiring diagram or some explanation how to do it.
Ill try tsr see if they will help but dont wanna pay someone to do it if it can be done by myself
Offline Softishman
« Reply #8 on: April 18, 2015, 06:37:30 am »
Post your solutions here later on!
Offline Wash
« Reply #9 on: April 18, 2015, 11:40:57 am »
I'm currently getting quite bad fuel cut at higher revs, already replaced hpfp for an autotech one, changed the fuel filter and changed the lpfp for another used one. Did some logging on VCDS and the fuel pump struggles at higher revs and doesn't maintain 6 bar of pressure (which I believe is what it should be). Was going to get an rs3/ttrs lpfp but now it looks a bit more complicated than that...
Offline aarondsg
« Reply #10 on: April 18, 2015, 12:12:41 pm »
if i get a solutiion will do
« Reply #11 on: April 20, 2015, 04:51:17 pm »
I thought the (standard) pump was variable pressure, 4 - 6 bar?  So long as it doesn't fall below 4, it should be OK.
Offline Wash
« Reply #12 on: April 20, 2015, 09:03:59 pm »
Well it was reaching 100% duty cycle and 4bar when I'm reaching higher revs which then results in fuel cuts for me.
Offline basman
« Reply #13 on: April 27, 2015, 10:43:51 pm »
any news on this?? @vRSAlex @aarondsg
« Reply #14 on: April 28, 2015, 12:30:19 pm »
Rs3 control harness fixes it apparently it's the easy option but expensive
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
