Author Topic: Brake problems  (Read 1124 times)
Offline Rickie47
Brake problems
« on: April 16, 2015, 10:06:11 pm »
So yesterday i changed my Diverter valve on my car which really needed changing after I pulled the old one out and then thought I know I'll take it out for a drive. However after a good 15 min blast around the roads I got home and could smell burning. It turned out to be my rear right hand brake. Now the only thing I'm thinking off is that I've pulled on the handbrake a bit to hard before lifting it to change the dv valve and its stuck on. I've sprayed brake cleaner on the brake and give it a jet wash as I have done a lot of mileage 2000 miles over the last month. I've taken it for a ten minute raging and it then seemed fine but is there any other checks I can do myself to put my mind at rest?
Offline cooljimy84
    • Personal
Re: Brake problems
« Reply #1 on: April 17, 2015, 10:46:07 am »
Jack the back up and spin the wheel.
Or better yet get a mate to pull the release the handbrake and foot brake while you spin the wheel by hand, to give u peace of mind.
Mate have a Nova that the handbrake used to bind abit if pulled to hard. A few hits with a hammer freed it up and it never happened again.....
There is no replacement for displacement....
But a turbo does help....
Offline Rickie47
Re: Brake problems
« Reply #2 on: April 17, 2015, 10:34:14 pm »
I've taken the caliper off and tried to wind it in won't move in what so ever. I tried the other side and it winds in a little so I guess it's time for some new calipers  :sad1:. Cheers thoe for helping out  :happy2:
Offline mvb12
  • -Receive: 64
Re: Brake problems
« Reply #3 on: April 18, 2015, 11:13:41 pm »
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
Re: Brake problems
« Reply #4 on: April 19, 2015, 11:31:04 am »
Did you open the brake fluid cap under the bonnet when you tried turning the caliper back in
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
