Author Topic: Knock when changing gear on full throttle  (Read 1045 times)
Offline TaylorGTi
« on: April 17, 2015, 06:23:02 pm »
When going from 2nd to 3rd when driving hard I'm getting a knock, Iv just had my stage 2+ map so am assuming with more torque the mounts arnt up to the job which is causing something to move but how shall I go about diagnosing what needs updating. Any help would be appreciated!
R-tech Stage 2+ Pirelli Gti
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Knock when changing gear on full throttle
« Reply #1 on: April 17, 2015, 06:30:43 pm »
It's possibly an engine mount that's causing it rather than anything suspension related.
I'm not sure how you would effectively nail down the exact culprit, but uprating engine mounts is a worthwhile job in itself when you're tuned, so maybe it's worth the investment knowing there's a good chance you'll cure it.
Sometimes it's a case of replacing mounts and bushes starting at the cheapest, and sometimes that gives you an excuse to upgrade.
Best of luck.
Offline TaylorGTi
« Reply #2 on: April 17, 2015, 06:37:48 pm »
Yeah im thinking that aswell as dog mount insert. Am I right in thinking that will reduce engine movement under load?
