Author Topic: Aircon not working  (Read 4892 times)
Offline caviarjim
Aircon not working
« on: April 18, 2015, 03:23:31 pm »
I have a 2006 gti and the aircon is not working. I had a chap out yesterday to re-gas the system but it was already full and he said that the refrigerant wasn't circulating, the pump is not engaging and the rad fans are not turning. I have read on the forum that the pressure switch can go and my question is this.
  If the pressure switch does go would this cause the whole system to shut down?
Also is there a way of testing the pressure switch to see if it is the culprit (I presume can be tested with VCDS but don't have access to one).
Finally is there a kindly forum member near Stockbridge, Hants that could do a fault code check if necessary.
Any help would be much appreciated.
Offline martin@gti.co.uk
Re: Aircon not working
« Reply #1 on: April 18, 2015, 10:01:18 pm »
vcds will tell you.
Could be low pressure swich at fault.
Offline skard
  • -Receive: 245
« Reply #2 on: April 18, 2015, 10:47:44 pm »
As above, measuring blocks will indicate what is stopping the compressor from engaging.
Have a peak down with a torch and see if the shear plate on the compressor pulley has sheared
Offline caviarjim
« Reply #3 on: April 19, 2015, 09:06:27 am »
Thanks for that. Will have a look this morning.
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #4 on: April 20, 2015, 02:43:34 pm »
Mine done this the weekend and need someone to scan it. First thoughts was the compressor/pump had died but seeing this has brought some hope it's not gonna be a mega expensive fix.
Offline caviarjim
« Reply #5 on: April 20, 2015, 07:19:12 pm »
So  Degudodger came round at the weekend and put the VCDS on my car. He is 70% sure that it is the pressure valve. I have ordered one today and will have a go at fitting it this week. Hopefully this will cure the ill aircon!
Offline caviarjim
« Reply #6 on: April 23, 2015, 02:02:42 pm »
I am hoping to swap my Air con sensor over this evening.  Is there anything that I need to watch out for or any tips a fellow member can share with me to make it easier. I have the new sensor, O ring and crow's foot spanner. Any advice would be greatfully received.
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #7 on: April 24, 2015, 09:50:38 am »
How did it go?
Offline caviarjim
« Reply #8 on: April 24, 2015, 09:59:59 am »
Badly! Having real problems getting the electrical connector detached from the top of the sensor. My arms are to big to get a decent grip on it and I have ripped them to shreds! Going to try again tonight and I will let you know how I get on.
Offline caviarjim
« Reply #9 on: April 24, 2015, 07:03:04 pm »
So I replaced the pressure switch and it doesn't seem to have fixed the problem. I have now reached the limit if my technical knowledge so looks like I will have to bite the bullet and take it to a dealer next week.
Offline skard
  • -Receive: 245
« Reply #10 on: April 24, 2015, 08:07:00 pm »
With the engine off, see if the bolt in the middle of the pump pulley seems loose and report back
Offline pandahouse68
« Reply #11 on: April 24, 2015, 08:08:13 pm »
Google :N280 valve :happy2:
Offline caviarjim
« Reply #12 on: April 24, 2015, 08:48:30 pm »
That's for the advice guys, will check the bolt in the morning. Will Also do some research on the N280 valve
Offline caviarjim
« Reply #13 on: April 25, 2015, 09:24:51 am »
 I have checked the bolt and it seems to be tight.
Offline skard
  • -Receive: 245
« Reply #14 on: April 25, 2015, 10:09:50 am »
Shear plate on the end is likely to be ok.
What you need is someone to put VCDS on your car and do some measuring blocks to see why the pump is not activating.
