Author Topic: Flat Battery  (Read 2831 times)
Offline K1NGY14
Flat Battery
« on: April 18, 2015, 07:03:11 pm »
Hi all,
I had a bit of a problem with my GTI this morning where is tried to start it up and it struggled at the first time of asking. I didn't think anything of it but when I tried to start it again 10 minutes later I got the constant clicking noise as the battery had gone flat.
Now when I left the car last night there was nothing left on that would drain the battery and I found it totally strange that it would just die like it did, is there anything that could of possibly drained my battery over night?
And now I have left the car hooked up to a charger is there a chance of it happening again?
Offline Andy-GTI
Re: Flat Battery
« Reply #1 on: April 18, 2015, 07:30:03 pm »
how old is the battery?
Offline StuF
  • -Given: 31
  • -Receive: 38
Re: Flat Battery
« Reply #2 on: April 18, 2015, 07:36:29 pm »
Have you added any new bits? Headunit that sort of thing?
Offline Andy-GTI
Re: Flat Battery
« Reply #3 on: April 18, 2015, 08:14:48 pm »
I had loads of issues with my 6R on a 60plate & original battery. Car going flat randomly, brought engine warning lights, with various errors recorded too. All it turned out to be was my battery was running at about 40%. Sometimes it worked on start up and sometimes it never, even after a good run out it would sometimes fail after leaving it a few hours. Sometimes work after 2 days leaving the car!. I paniced as the symptoms didn't sound like battery issue, and that something was draining it. New battery on and was fine.
Offline K1NGY14
Re: Flat Battery
« Reply #4 on: April 18, 2015, 10:35:41 pm »
I think the battery came with the car which is an 08 plate.
No nothing has been added to it recently, which is a bit concerning!
By the sounds of it I will have to look at getting a new battery
Offline Andy-GTI
Re: Flat Battery
« Reply #5 on: April 18, 2015, 11:49:47 pm »
Hope it turns out to be that. Easy replacement and after 7 years use its not a bad thing to have to replace anyways.  :happy2:
Offline K1NGY14
Re: Flat Battery
« Reply #6 on: April 19, 2015, 12:58:42 pm »
Yeah I agree mate, I will get down to ECP next week. Do you have any recommendations of which one to buy?
Offline Andy-GTI
Re: Flat Battery
« Reply #7 on: April 19, 2015, 01:19:09 pm »
Pretty sure mine was a Bosch but it was a 6R so different car, can only assume Bosch are decent. Had a choice between 2 and the Bosch was only a few £ more so went with the branded name.
Re: Flat Battery
« Reply #8 on: April 19, 2015, 03:43:07 pm »
Battery can just go like that..I replaced mine and bought the bosh one
Offline K1NGY14
Re: Flat Battery
« Reply #9 on: April 26, 2015, 01:24:26 pm »
Yeah I have just had it tested and it was the battery that was the problem, he said it was working to about 40% capacity!
