Author Topic: Subwoofer install guide?  (Read 2256 times)
Offline AndyBrown
« on: April 20, 2015, 08:54:01 pm »
Is there a guide anywhere for installing a sub?
I've had a search but can't find anything.
I'm not going to wild just a small sub to pack a bit more punch to the standard system.
I'm presuming there's a grommet in the bulkhead that I can feed the power cable through?
What's the best way to run the wiring? Remove front seats and pull the carpet up?
Cheers guys
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=0eda9ihpu7ediu03n28tfbo30b&/topic,90967.msg917089.html#msg917089
Re: Subwoofer install guide?
« Reply #1 on: April 21, 2015, 12:11:54 am »
If you have DSG there is a grommet where the clutch would go. Don't bother removing the seats just remove the plastic trim that runs along the side. Unless you plan to put the amp under one of the seats.
05 | Tornado Red | DSG
