Author Topic: LPFP - Bit of help please  (Read 3701 times)
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
  • Instagram & YouTube - mateyguv
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,69555.0.html
« on: April 21, 2015, 10:27:52 am »
Took my 2007 Edition 30 DSG for a short drive yesterday and while moving in slow traffic the accelerator stopped providing acceleration yet the gear indicator said it was in gear. The engine then stalled. I was able to put the car into neutral and restart it then got back home. Later on I went to start the car and all good, went down the road and engine management light came on and when coming to a stop engine stalled again.
Got it home and started again but would only idle for a few seconds then stall again. Plugged my scanner in (eBay special) and no fault codes but eml still on. Disconnected the battery and left for 5 then reconnected and it started and was able to idle for about a minute then died again. I have ordered Ross tech and will have it tomorrow so will scan when I get it.
Any ideas from anyone from what I'v said? I do have a forge catch can that I'v noticed a fine layer of oil on the hoses so I'm thinking possible that may have a leak in it?
Any ideas would be appreciated  :happy2:
« Last Edit: April 22, 2015, 08:52:24 pm by MateyGuv »
Offline Dave J
  • -Given: 45
  • -Receive: 63
Re: Bit of help please
« Reply #1 on: April 22, 2015, 08:31:25 pm »
Mine did exactly that last October - kept dying at idle in 'D' or 'N' one evening. Turned out to be the LPFP, but I wasn't getting an EML. Error code that showed up on mine was P310B.
VW changed the LPFP & then the car was showing an EML, despite the fuel pressure being correct when they did their data logging. The diagnosis then was that a new LPFP sensor was needed - 06E 906 051K. That was changed and the car has been ok since.
Edition 30 - no. 1387
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #2 on: April 22, 2015, 08:37:41 pm »
Cheers for the help Dave  :happy2:
I'v auto scanned the car and an intermittent LPFP has been recorded.
Also, rather embarrassingly, my catch can was full so I'v emptied that and car now idles without stalling. Just letting it get up to temp now to see if it'll stall then gonna take it for a run and see if it happens again. I'll scan it again when I get back.
Thanks again for the help and part number
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #3 on: April 22, 2015, 08:41:04 pm »
No worries - hope the catch can is all it was then!
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #4 on: April 22, 2015, 08:43:24 pm »
Looks like it's more than the catch can. It ran fine for about 5 mins then stalled again  :sad1: Running another scan now
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #5 on: April 22, 2015, 08:51:59 pm »
Looks like the problem is with the LPFP. I think I'll try the sensor first then look into the pump. Do you know where the sensor is Dave? @Dave J
I do have a 4WD LPFP, anyone know if this can be used??
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G93NM7R3
   Coding: 040300031C070160
   Shop #: WSC 01279 785 00200
   VCID: 377D17514684DB999F5-8062
2 Faults Found:
004767 - Low-Pressure Fuel Pressure Regulation
               P129F - 001 - Pressure too High - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 71727 km
                    Time Indication: 0
                    Date: 2015.04.22
                    Time: 22:23:54
             Freeze Frame:
                    RPM: 1094 /min
                    Load: 32.5 %
                    Speed: 0.0 km/h
                    Temperature: 33.0°C
                    Temperature: 19.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.097 V
012555 - Low Pressure Fuel regulation
               P310B - 001 - Fuel Pressure Outside Specification
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 71727 km
                    Time Indication: 0
                    Date: 2015.04.22
                    Time: 22:24:53
             Freeze Frame:
                    RPM: 1049 /min
                    Load: 18.0 %
                    Speed: 0.0 km/h
                    Temperature: 42.0°C
                    Temperature: 18.0°C
                    Voltage: 14.224 V
Readiness: 0110 0101
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
Re: LPFP - Bit of help please
« Reply #6 on: April 22, 2015, 09:49:53 pm »
@fuscobal
Is it as easy as your build thread seems, do I need coding done or is it plug and play?
Any help would be great mate  :happy2:
Offline fuscobal
  • -Receive: 27
« Reply #7 on: April 23, 2015, 12:09:41 pm »
Was plug and play for me with only the floating mechanism mod ! TTRS pump should be ok with no software mod but could burn the OEM controller, in which case you should also buy the TTRS one ! For me the OEM controller worked fine and I've had a few track days with it on the TTRS pump !
« Last Edit: April 25, 2015, 08:17:49 pm by fuscobal »
Mk5 GTI 6MT - Revo stage 3
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #8 on: April 23, 2015, 12:11:01 pm »
Thank you dude  :happy2:
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #9 on: April 24, 2015, 12:00:33 am »
Iv replaced the thrust sensor and it appears to be fine now - fingers crossed!! Thanks guys  :happy2:
