Author Topic: r32 front brakes  (Read 4126 times)
Offline Stooey
r32 front brakes
« on: April 22, 2015, 06:32:29 pm »
I'm getting my r32 front calipers fitted on the 6th and want to get braided hoses for them, I have been looking on the internet and have been in contact with one company who say the r32 hoses are 475mm long ant the gti ones are 585mm, so are unsure which I need, can anybody shed some light on this? Also they said that they only do the gti rears over the rear beam and not to the caliper as the cant replicate the standard ones, is tho correct or are they just talking crap?
Cheers in advance :drinking:
Offline Stooey
Re: r32 front brakes
« Reply #1 on: April 23, 2015, 05:33:55 pm »
Can anybody help??
Offline Matto
  • -Receive: 116
« Reply #2 on: April 23, 2015, 09:01:41 pm »
Have a word with @vRSAlex (Alex @ AKS Tuning). He does some HEL braided specifically for the R32 setup. He has recently fitted my set and its made a nice improvement.  :happy2:
Offline skard
  • -Receive: 245
« Reply #3 on: April 23, 2015, 09:06:23 pm »
You get different variants of hoses. One set is longer as they eliminate the rigid pipe behind the caliper. The other set mates onto the rigid pipe and is thus a bit shorter.
R32 hoses are longer than GTI ones, but I can't remember numbers
Offline Matto
  • -Receive: 116
« Reply #4 on: April 23, 2015, 09:14:30 pm »
The set I have had the part number VAG10. Think they are specials. They are single piece with a 45 degree banjo fitting on the caliper end which then connect to the solid pipes on the inner wing.
Offline skard
  • -Receive: 245
« Reply #5 on: April 23, 2015, 09:23:33 pm »
I think this is what I got from DaveB on my old car, took off the extra joint of the rigid pipe.
Offline Matto
  • -Receive: 116
« Reply #6 on: April 23, 2015, 11:54:51 pm »
Yeah sounds right. I believe the ones I have are DaveB specials  :happy2:
Offline Stooey
« Reply #7 on: April 27, 2015, 05:07:30 pm »
Anybody know where I can get these as I have tryed to contact DaveB through pm and vRSAlex via pm and aks tuning email and havnt received a reply from either.
Offline Stooey
« Reply #8 on: April 28, 2015, 07:31:34 am »
Do normal r32 braided hoses fit? Need to know today really as need them before the 6th
« Reply #9 on: April 28, 2015, 07:51:32 am »
i just put the normal flexis pipe on mine wth no hassle at all
Offline skard
  • -Receive: 245
« Reply #10 on: April 28, 2015, 07:59:22 am »
If your caliper has the rigid pipe on the rear, then standard r32 hoses are fine
Offline Stooey
« Reply #11 on: April 28, 2015, 09:16:15 am »
This is my r32 calipers, does this mean that r32 braided hoses will fit these to my gti no problem?
Offline skard
  • -Receive: 245
« Reply #12 on: April 28, 2015, 10:03:53 am »
Yes just standard length R32 hoses will do. Same fittings you have now on the rubber hose but a little longer in length
Offline Stooey
« Reply #13 on: April 28, 2015, 12:17:53 pm »
So I assume these should fit fine?
http://m.ebay.co.uk/itm/321701417933?nav=SEARCH
Offline Stooey
« Reply #14 on: April 28, 2015, 07:05:52 pm »
Or will these fit? They say they fit the gti AND the r32??
http://shop.lvsracing.co.uk/mk5-platform-hose-technic-brake-hoses-fwd4wd-1265-p.asp
