Author Topic: Air con high pressure valve  (Read 1155 times)
Offline caviarjim
« on: April 23, 2015, 07:06:01 pm »
Evening chaps. I have just spent the last hour or do trying to remove the electrical connection on the top of the air con high pressure switch but with no luck. Is there a knack to removing it? I have ripped my arms to shreds!
Any help would be greatly appreciated.
Offline beetie
  • -Given: 34
Re: Air con high pressure valve
« Reply #1 on: April 24, 2015, 06:23:40 pm »
Helps to push it on before pressing in the releasing clip, then pull off.
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« Reply #2 on: April 24, 2015, 06:52:00 pm »
As above, they are designed to take off without yanking etc. Simply push in and pull back ;)
Offline caviarjim
« Reply #3 on: April 24, 2015, 06:59:16 pm »
Thanks chaps. Got a friendly mechanic (with thinner arms) to get if off for me. Unfortunately it doesn't seem to have solved the problem. Back to the drawing board....
