Author Topic: Horrible grinding/rubbing noise that's getting worse  (Read 1355 times)
Offline Hashmk5
  • My Ride: MK5 Golf 04 plate
« on: April 23, 2015, 10:59:04 pm »
Hi guys so today on my way home, whilst breaking I heard a small grinding noise, as I carried on further and breaked more I realised it was coming from one of the back wheels and seemed to get worse, at one point in the journey I had to break quite harshly and now the noise is almost constant even whilst the car is moving at low speeds dispite breaking! Any ideas what this could be? I have an early morning exam tmro and need to know if the cars safe to drive or if I need to make alternative arrangements
Offline KieranED30
  • Burning Rubber Since 16th Febuary 2012
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89941.0.html
Re: Horrible grinding/rubbing noise that's getting worse
« Reply #1 on: April 23, 2015, 11:24:47 pm »
Ermmmmm have you got any brake pads left??  :signLOL:
Metal on metal grinds  :scared:
Offline Hashmk5
« Reply #2 on: April 24, 2015, 12:09:15 am »
It should do they wre changed recently-ish, it goes away for abit and comes back I just took it for another wer spin
Offline GTIEagles
« Reply #3 on: April 24, 2015, 09:16:22 am »
I would say that a stone might be stuck between your brake disc and backplate. Easy to diagnose, jack your car and spin the wheel if it is grinding try bending the back plate to see if anything drops out.
Offline cooljimy84
    • Personal
« Reply #4 on: April 24, 2015, 10:35:17 am »
Had this a few times in mine. I ended up finding a quite road and reversing for a few meters and the stone dropped out. Tho if it's worked it's self deeper you might have to start with the taking bits apart...
There is no replacement for displacement....
But a turbo does help....
