Author Topic: After market HU won't power down.  (Read 788 times)
Offline GTIdanman
« on: April 23, 2015, 10:59:44 pm »
So today I decided to fit my setero in to my mk5 gti. All went well. Sounds good looks good, but when I took my keys out the dam thing stayed on. It seems the only way to switch it off is by removing the face plate. And I'm a bit worried I may wake up to a flat battery as it's obviously still got power even when the ingnition is off. Any body know what I have done wrong or what I can do to fix it. I used an adapter kit from halfords to attach the wires in the back.
Re: After market HU won't power down.
« Reply #1 on: April 23, 2015, 11:09:57 pm »
you need to put one of the wires of the h/u to ignition live
Offline paulw123
  • -Receive: 47
« Reply #2 on: April 24, 2015, 03:35:07 pm »
Sometimes on vw's you need to change the red and yellow wires around, so that red goes to yellow and yellow goes to red.
That's what I did with a sony in a mk4 golf.
Offline Blackgtiman
« Reply #3 on: April 24, 2015, 05:29:47 pm »
in the mk5 you must run a new switched live from the fag lighter or fuse box. the oe unit is controlled by canbus you see.
