Author Topic: Coolant  (Read 756 times)
Offline No1gooner
Coolant
« on: April 25, 2015, 08:46:08 am »
May be a dumb question but I've been told that I can top up my coolant with G13 when my car currently has quantum red long life in the system as there both VW spec, I'm still not sure as don't want to mix the 2 if it's gunna end up f*ckin the engine, gasket or something. Should I just flush the quantum and start fresh with G13?
Thanks All
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Coolant
« Reply #1 on: April 25, 2015, 10:28:24 am »
I would stick with the stuff you already have in the system if you can still get it. If not check the spec on the label & if it matches you should be ok?.
