Author Topic: Noise when turning left  (Read 1253 times)
colins
« on: April 25, 2015, 09:59:51 am »
Hi all,
 I have a vibration type noise when turning left, seems fine when straight and turning right. The noise persists when in neutral with the clutch down.
Having had a look under the car the near side outer cv boot has split, and there's a fair amount of grease around which has escaped from the joint.
Are these symptoms typical for a damaged cv joint or is that likely to be a secondary problem?
Thanks!
Offline Flyingscotsman
Re: Noise when turning left
« Reply #1 on: May 11, 2015, 08:42:51 pm »
Clicking or vibration when turning is a symptom of a failed CV joint. Sounds and looks like that's your problem.
