Author Topic: Problem with high beam  (Read 1741 times)
Offline Wildengti
« on: April 26, 2015, 01:21:59 pm »
Anyone had the reflector drop and come loose in GTI black headlights?? My passenger side has come loose when fitting new bulb?
Anyone had the problem? Easy fix or new headlight?
Instagram- sam__gti
Mk5 GTI OEM+ BBS CH
Re: Problem with high beam
« Reply #1 on: April 26, 2015, 01:32:27 pm »
It might of just come out of the clip,if snapped it's a new one,thier was a set for sale on here
Offline Wildengti
« Reply #2 on: April 26, 2015, 01:40:55 pm »
Will I have to take the headlight out to try fix it??
Instagram- sam__gti
Mk5 GTI OEM+ BBS CH
« Reply #3 on: April 26, 2015, 02:01:55 pm »
It's easier to do with the head light out,only down side if the light is broken you will have to do it all again if you need the car for work
Offline Wildengti
« Reply #4 on: April 26, 2015, 02:28:22 pm »
Luckily I don't need it for work :) do you have to take the bumper off? Seen a thread where they removed the bumpstrip under the light to get to the bottom screw??
Instagram- sam__gti
Mk5 GTI OEM+ BBS CH
« Reply #5 on: April 26, 2015, 02:37:05 pm »
I did on mine,as mine has the old bumper on it being a gttdi,if you have a gti you might need to remove the bumper
