Author Topic: engine / engine cover rock  (Read 2089 times)
Offline Pesky jones
« on: April 26, 2015, 09:05:52 pm »
Is it normal for the engine or engine cover to rock when you rev it?
Offline mk5-beast-91
  • instagram: subarukid24
Re: engine / engine cover rock
« Reply #1 on: April 26, 2015, 09:15:47 pm »
engine mounts sound warn out. youll get some movement as its for comfort but excess is down to warn out mounts.
my strength lies solely in my tenacity
Offline K9
  • VW LifeStyle
« Reply #2 on: April 26, 2015, 09:21:27 pm »
@mk5-beast-91 do you have the part nr. for the engine bushes? as i got 2 worn out  :scared:
Edit: found it! :happy2:
« Last Edit: April 26, 2015, 09:24:09 pm by K9 »
« Reply #3 on: April 26, 2015, 09:28:58 pm »
1K0 199 262 M (right engine mount)
1K0 199 555 Q (left gearbox mount)
1K0 199 867 A (rear subframe bush)
Offline Pesky jones
« Reply #4 on: April 26, 2015, 10:48:02 pm »
So what does work out engine mounts entail? I take it you can't do it yourself...
Offline Pesky jones
« Reply #5 on: April 26, 2015, 10:54:00 pm »
I also should mention that the engine cover is only secured at the front, the two back cover mounts have perished. I've ordered some new ones already.
« Reply #6 on: April 26, 2015, 10:58:39 pm »
not sure what the engine mounts cost as ive uprated to vibratechnic ones. there an easy fix tho. done mine on the driveway with some axle stands. took about an hour in total to do. really easy job and only need basic tools.
Offline Pesky jones
« Reply #7 on: April 26, 2015, 11:11:32 pm »
Is it just axle stands and basic tools then? No specialised tools?
« Reply #8 on: April 26, 2015, 11:22:42 pm »
if i remember correctly its only 10mm, 13mm, 16mm and 18mm deep sockets. and t20 or t25 torq driver. and torque wrench to. and a trolley jack to support engine from underneath while swapping the mounts.
Offline Pesky jones
« Reply #9 on: April 26, 2015, 11:31:03 pm »
Haha so not basic tools.
I've got the rest apart from torque wrench and trolley jack. Do I really need a torque wrench? Definitely don't have a trolley jack. Might have to leave this one... Perhaps it's not excessive movements. It rocks forwards to the front of the car by about an inch or two. Should I post a video?
Offline Pesky jones
« Reply #10 on: April 27, 2015, 08:28:41 am »
I could just get it done by a garage I guess. Any idea on how much you think it should be? Cheers
Offline Pesky jones
« Reply #11 on: April 27, 2015, 10:33:15 am »
Is this a serious issue with bad consequences btw?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #12 on: April 27, 2015, 12:44:28 pm »
Engine could drop out if mounts fail  :surprised:
Few guys have had this happen when cambelt replaced, but garage have re-used engine mount stretch bolts. . . Moral of the story is - don't re-use stretch bolts.
Soft mounts also affect the cars handling as the weight of the engine is thrown around the engine bay.
Offline Pesky jones
« Reply #13 on: April 27, 2015, 01:59:16 pm »
I've spoken to someone and they say an inch or two of movement forward isn't too bad. It's when its really rocking three or four inches that's a problem.
« Reply #14 on: April 27, 2015, 05:34:09 pm »
2 inches sounds alot to me. id get them changed for piece of mind.
