Author Topic: Dsg gear oil change question  (Read 2886 times)
Offline so1o
« on: April 27, 2015, 06:10:03 am »
Hi guys
I'm going to hopefully change my dsg gearbox oil and filter over the next few days.
Where is the overflow plastic tube thing located?
Few days ago whilst under the car I saw the drain plug but could not see the plastic bit?
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
Re: Dsg gear oil change question
« Reply #1 on: April 27, 2015, 12:07:00 pm »
Hi mate check this video about 3:30 in...
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=pa9jc4ir797eom0ftmtnael4b9&/topic,90967.msg917089.html#msg917089
« Reply #2 on: April 27, 2015, 12:13:28 pm »
How are you planning to fill it?
Measure and replace or using VCDS?
Fill through filter housing?
Fill with fill tool?
« Last Edit: April 27, 2015, 12:21:39 pm by dazza »
05 | Tornado Red | DSG
Offline so1o
« Reply #3 on: April 27, 2015, 04:14:53 pm »
Thanks for the replies guys.
I have vcds. Will get it up to temperature.
Fill through filter hole. I thought instead of measuring you could fill it up and the plastic thingy would just let the excess out.
Am I correct or totally wrong? I could measure it if needs be.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #4 on: April 27, 2015, 04:38:25 pm »
If you have VCDS then u can fill and drain off excess when at correct temperature.
Make sure the car is level. I used 4 axle stands.
Offline so1o
« Reply #5 on: April 27, 2015, 09:17:51 pm »
im sure I read somewhere that you can do the oil change with it 5 litres but u think I also saw somewhere where it said you need 6 litres.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #6 on: April 28, 2015, 12:28:19 am »
I used 5 but about one litre of oil stays in the system. So adding 6 litres would help to flush more of the old oil out.
Offline so1o
« Reply #7 on: April 28, 2015, 06:03:07 am »
Thanks for the help guys n
Offline so1o
« Reply #8 on: April 29, 2015, 06:35:54 am »
I'm going to do the oil change today.
I will make sure car is flat. I will drain the oil and measure to see how much came out. I will add in exactly what came out +0.1/2L to make up for the oil in filter housing.
Doing it this way I don't need to use vcds do I? As I have put back exactly what came out. Correct?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #9 on: April 29, 2015, 07:58:06 am »
As you have VCDS you may as well do it the correct way. Maybe it was not filled correctly in the past.
Offline so1o
« Reply #10 on: April 29, 2015, 11:21:40 am »
Cheers for the help people. Just done the change. Took a little over an hour. I didn't remove my battery tray. The longest bit was filling it through the top.
