Author Topic: General track day tips for a noob  (Read 8584 times)
dansmith180
Re: General track day tips for a noob
« Reply #15 on: May 01, 2015, 09:41:32 pm »
Keep checking your tyre pressures as they will increase as your tyres get hotter.
Unless you run on Michelin Pilot super sport, they will have a minimal increase due to the use of twaron instead of steel
I am running the super sports mate, what PSI would you recommend starting at and what be my target 'hot' PSI? I was thinking start at around 35 (they're 225/40/18's) and not let them go above 39 - 40
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #16 on: May 02, 2015, 08:42:56 am »
You should keep the 35 and not have to worry about letting out air as the twaron keeps the tyre cooler than other tyres. At donington i just kept the pressure from the road and there was no need to adjust despite it being almost 30 degrees celsius on that day
Over the top mod list ;o)
dansmith180
« Reply #17 on: May 02, 2015, 10:53:04 am »
Nice one, thanks  :happy2:
