Author Topic: aftermarket hid kit  (Read 1795 times)
Offline cander83
aftermarket hid kit
« on: April 28, 2015, 08:44:50 pm »
Hi ppl been having major headaches with the HID kit that was installed on my mk5 ed30. Looking to remove this and just replace with good quality bulbs . Anyone know if this is easy enough to do ...if intensive the HID kit will there be a connection in place for a standard bulb to fit back on ...Any advice is much appreciated ...thanks
Offline Milkman123
  • My Ride: Black GT 170TDi. Full leather, RCD510, 18" charlestones, MDI., only 35k on her from new
Re: aftermarket hid kit
« Reply #1 on: April 29, 2015, 09:11:48 am »
There should be original H7 connector floating about inside the unit if it's a normal headlight halogen. If it is pull all that hid out I'm running osram 110% bulbs. Brilliant. Really bright been running 24/7 as drl still good after 14 months.
Kam88
« Reply #2 on: April 29, 2015, 07:18:18 pm »
just need to unplug it and thats it all your original fittings should be there should take you 2 minutes
Offline cander83
« Reply #3 on: April 29, 2015, 08:11:45 pm »
Cheers guys . Just wanted a heads up before I take plunge and pull them out
