Author Topic: Help I need brakes :D  (Read 2201 times)
Offline Mitch H
  • -Receive: 25
« on: April 29, 2015, 09:07:46 pm »
R tech next month for a map.
Should be around 330bhp
As a result I need some bigger brakes don't want to spend thousands.
Been looking at the likes of the 'nqsbbk'.
I also need some bilstein suspension and an alk or tt console bushes but that's for another day.
Someone point me in the right direction here? Where to buy and everything I need. I Tryed pm'ing aks alex but have since read that he is very very busy atm which is fair enough
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Help I need brakes :D
« Reply #1 on: April 29, 2015, 10:38:37 pm »
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #2 on: April 29, 2015, 10:46:18 pm »
Offline Mitch H
  • -Receive: 25
dansmith180
« Reply #4 on: April 29, 2015, 11:08:04 pm »
Yeh a bit too pricey
Thoughts on these?
http://www.mk5golfgti.co.uk/forum/index.php/topic,96717.0.html
Or these?
http://www.mk5golfgti.co.uk/forum/index.php/topic,93498.msg936707.html#msg936707
With that RS3 setup you'd need the TTRS disc or AKS brackets and R32/ TTS discs (which is what I use and they're fantastic).
Offline flashp
  • -Receive: 65
« Reply #5 on: April 30, 2015, 08:24:08 pm »
S3 parts front and rear will be fine for road use.  Spec performance pads and fluid. S3 rears are vented in case you didn't know.
Gone but not forgotten :-)
Offline Mitch H
  • -Receive: 25
« Reply #6 on: April 30, 2015, 10:49:06 pm »
I'll look into these mate cheers are they the same as r32? As a lot say the r32 brakes are really heavy thanks for your help
Offline flashp
  • -Receive: 65
« Reply #7 on: May 01, 2015, 06:57:17 am »
They are heavy, whether you notice or not is another matter. They're a great value upgrade. On track they will get out of their depth at some point. I never had any issues at all at 340hp with road use. Decent pads and fluid are a must. If I didn't use mine for track days I'd probably still be using them.
I offset the weight gain by fitting S3 arms which are half the weight of the steel oe. They add a little more castor angle and the S3 bushing supplied is stiffer than oe golf. Add a WALK kit and it's a great addition.
« Last Edit: May 01, 2015, 07:01:28 am by flashp »
