Author Topic: Variations of Polar FIS  (Read 6148 times)
Offline Lyons
  • -Given: 18
« on: April 30, 2015, 02:11:15 pm »
Folks, I'm looking for a Polar FIS to enable the Bluetooth to be controlled by the highline.
Can anyone tell me what the differences are between the various models? I'm not bothered about the other info available, it's just the Bluetooth control that I need.
Is this all I need;
http://www.carsystems.pl/fis-link-can-box-converter-for-red-dot-matrix-fis-and-new-bt-modules,id687.html
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Variations of Polar FIS
« Reply #1 on: April 30, 2015, 02:29:24 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,95592.msg958414.html#msg958414
I fitted a kit from Carsystems.pl this last weekend. :wink:
I guess you can get a newer module and get the Polar BT separately and all should work as well. With this version J I got what I was looking for. :smiley:
A Polar FIS is a different module. You just need the Polar BT/Battery (PB01).
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #2 on: April 30, 2015, 02:41:06 pm »
Offline Lyons
  • -Given: 18
« Reply #3 on: April 30, 2015, 03:01:43 pm »
Cheers, I'd seen that but it's said it was for White highlines only. I can see you got it working though!
Can I ask why you got it and the Polar FIS Advanced? I thought the latter got the Bluetooth working too?
Offline DANBOY66
  • -Given: 41
« Reply #4 on: April 30, 2015, 03:04:35 pm »
i have the vw bluetooth and polar fis kessy Edition and i have a fully working mfa and steering wheel button control  :happy2:
Dan..
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #5 on: April 30, 2015, 07:15:55 pm »
@Lyons My Eddie came from factory with a 5N0 Premium Bluetooth module that worked perfectly with the Polar FIS Advanced, but the module was too old to connect with my iphone so I got a new module 7P6 that can connect with my phone. The Polar BT allows the new module to show and be controlled from the cluster and steering wheel and not just from the RNS-510.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #6 on: April 30, 2015, 07:17:32 pm »
What part number does your Bluetooth module have?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: April 30, 2015, 07:30:44 pm »
Im guessing a 7p6.  The 5n0 and 729 both work in highline menu
Offline DANBOY66
  • -Given: 41
« Reply #8 on: April 30, 2015, 07:50:23 pm »
5K0 035 730 D
Dan..
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9 on: April 30, 2015, 09:05:18 pm »
5K0 035 730 D
If you get one of the newer versions only compatible with white clusters you'll need the Polar BT box. :wink:
Offline DANBOY66
  • -Given: 41
« Reply #10 on: April 30, 2015, 09:10:20 pm »
mine works on the highline red dot cluster
streams Bluetooth as well  :happy2:
Dan..
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #11 on: April 30, 2015, 09:26:46 pm »
Is it compatible with iPhone 5/6 too?
Offline DANBOY66
  • -Given: 41
« Reply #12 on: April 30, 2015, 09:29:29 pm »
yeah I have an iphone 5  :happy2:
worked on highline but had to use my rns510 but then I added my polar kessy and all steering wheel buttons started working and now I have full phone book on my highline and call list and so on just like a 2014 touran hire car I had  :happy2:
Dan..
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #13 on: April 30, 2015, 09:32:27 pm »
Nice, you now have the same functions as I have but cheaper.  :happy2:
Offline Lyons
  • -Given: 18
« Reply #14 on: May 01, 2015, 08:55:15 pm »
So the BT box at €120 all I need then?!
