Author Topic: Xenon coding issue??  (Read 2130 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« on: April 30, 2015, 06:59:31 pm »
Just checking if this right, coded some xenons for a member on here ( @rukz ). Coded it as xenons with shutter installed, wires are run to the cecm.  However when the xenons are off and you flash the lights, the halogens dont flash,the xenons do.  Is that correct?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Xenon coding issue??
« Reply #1 on: April 30, 2015, 07:21:46 pm »
There's another check box  (can't remember which one) where you can enable halogens. Work your way through all the check boxes and you'll find it
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #2 on: April 30, 2015, 07:29:03 pm »
I think I did check  that and try but then when the xenons were on and you flash, the halogens would flash as well as the xenon shutters. Really weird.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: April 30, 2015, 07:43:31 pm »
Sounds normal too be honest, think from memory mine does the same if you've both those boxes checked, I'm out at the minute but I'll double check for you later  :happy2:
Offline Rukz
« Reply #4 on: May 15, 2015, 09:47:01 pm »
Only just realised you started this thread @vw55raz  :happy2:
I do like the way it is now with the xenons flashing (looks like a far newer car).
However, I'm constantly worried incase the bulbs/ballasts get damaged or completely go :sad1:
Tornado Red | MK5 | GTi | DSG
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: May 15, 2015, 09:52:16 pm »
Yeah thats the only thing that i was worries about too,  the bulbs and ballasts
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #6 on: May 25, 2015, 01:02:19 pm »
@rukz had a look on another car to day which has factory fitted xenons  and his ones also do the same,  guess thats how they are.
Offline Rukz
« Reply #7 on: June 13, 2015, 08:12:15 pm »
Issue sorted thanks to @RetroRaz  :happy2:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: June 13, 2015, 08:46:23 pm »
Cheers  @rukz going to do this on mine this week and make a video tutorial.  Should interest a few people  :)
