Author Topic: High Pitched Squeeling When Coming Off Boost  (Read 1098 times)
Offline StuF
  • -Given: 31
  • -Receive: 38
« on: May 01, 2015, 09:07:26 am »
Good morning,
Today I was driving to work with the window open and noticed a strange noise when coming off boost
Basically when backing off the acclerator I hear a high pitched squeeling noise that sounds like a dry bearing - however the noise only happens when I back off pretty suddenly. Only lasts a second or so like pressure is being released.
Am I correct to assume it is a blocked or semi blocked PCV - car is an 08 GTI, unmapped and isnt loosing any boost when under load.
For interest sakes how much is a replacement PCV?
Many thanks for your help in advance  :happy2:
Offline StuF
  • -Given: 31
  • -Receive: 38
Re: High Pitched Squeeling When Coming Off Boost
« Reply #1 on: May 01, 2015, 09:18:08 am »
I have removed the dipstick with the engine running and the idle doesnt really change although the valve does make quite a noisy hiss
Will have to pop into VW today and grab one and see if that rectifies it!
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #2 on: May 01, 2015, 02:58:58 pm »
Fixed - new PCV from GSF for £25! Winner :happy2:
No more nasty noises
