Author Topic: Key immobiliser coding desperate help needed.  (Read 3094 times)
Offline so1o
« on: May 04, 2015, 05:41:05 am »
Hi guys
To cut a long story short I broke the little transponder chip in my key. I only have one key.
Know anyone in the Luton area who can program this for me? I am totally desperate as I can't use my car at the moment.
I have read various threads over the last few days and basically it said I can program the key using vagcom which I have.  I need to obtain the skc from the cars clocks or ecu using either vag commander or vag tacho. I have ordered the virgin transponder chip if it helps. Don't have it but should arrive with me Wednesday.
So can anyone help? I am utterly desperate.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Key immobiliser coding desperate help needed.
« Reply #1 on: May 04, 2015, 05:47:22 am »
You'd need one good transponder to copy it to a virgin one. With no good transponder I'm not sure you can get a key to work with your immobilizer unless you ask for a new key from VW.
I'll follow this topic to see if others know better.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #2 on: May 04, 2015, 08:08:12 am »
Have a read of this http://wiki.ross-tech.com/wiki/index.php/Immobilizer
Determine the type of immo you have. If it's the later challenge type you won't be doing it with either VCDS or the cheap Commander clone.
Offline so1o
« Reply #3 on: May 04, 2015, 02:29:09 pm »
Thanks guys.
I'm sure it's not the challenge type immobiliser.
Good news is found someone who can program it.
I will also give it a go by trying to program a key myself using the virgin transponders I ordered. Will let you know how I get on.
