You say et35 or 45 with spacers? If the wheels are et35 then any spacer will lower the offset. So an et35 wheel with a 10mm spacer gives a final offset of et25.
As for rubbing, it all depends how low you are. But at 8.5 wide I'd guess things could get a bit tight and you certainly wouldn't want spacers in the equation.
