Author Topic: Oil Pick up Inspection/Replacement/Cleaning  (Read 13706 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=qd5qhvf357tean6jj8e7l5l01o&/topic,19740.0.html
Re: Oil Pick up Inspection/Replacement/Cleaning
« Reply #45 on: May 16, 2015, 08:09:07 pm »
Made one. Cost about 3 quid  :smiley:
Seems a good idea but won't the magnetism pass through to the sump ? Where as the other plugs are insulated against the internal magnet. Will be interesting to see results
Good point...... might have to rethink  :signLOL:
Offline v4rley
  • -Receive: 104
« Reply #46 on: May 16, 2015, 08:14:20 pm »
Was just looking at buying some magnets when I thought about it  :sad1:
« Reply #47 on: May 16, 2015, 08:25:40 pm »
Yeah.... might also dissipate the magnetic power as well, instead of it being concentrated on the "tip.
Just gonna buy a mag. plug. Then if it picks up some stuff ill drop the sump next service.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #48 on: May 17, 2015, 02:07:07 pm »
How can it possibly be insulated against magnetism?  Last time i checked my sump wasn't magnetic anyway so bit of an invalid argument  :grin: Home made magnetic sump plug does the job perfectly for a fraction of the posh one
Why not see how powerful the magnetism is at the tip of the bolt? Mine was pretty strong
« Last Edit: May 17, 2015, 02:09:47 pm by Dan_FR »
Offline v4rley
  • -Receive: 104
« Reply #49 on: May 17, 2015, 02:29:17 pm »
Hardly an invalid argument, the fact I made an enquriey. Unfortunately I have neither a magnet or sump in my lounge to check, hence why I mention my thought.
If thats the case then great, I'll get some magnet and get them on the sump plug.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=qd5qhvf357tean6jj8e7l5l01o&/topic,90967.msg917089.html#msg917089
« Reply #50 on: May 17, 2015, 02:30:37 pm »
It should still work even if the sump is magnetised bits of metal held there will be flushed out when you drop the oil.
05 | Tornado Red | DSG
« Reply #51 on: May 17, 2015, 09:02:30 pm »
Thats true... the sump is aliminium.... bollocks. Ill have to stick them back on again!  :signLOL: :signLOL: :signLOL: :signLOL:
