Anyone know the torque for the bolt holding the pickup pipe??
Did you move your boost pipe clip @dazza or is it loose?
Just bought some 15x5mm neodymium magnets to make a mag. sump plug... see if it works.
Quote from: rich83 on May 15, 2015, 01:44:59 pmJust bought some 15x5mm neodymium magnets to make a mag. sump plug... see if it works. Ive had the ECS mag plug fitted for some time. Maybe lining the whole of the bottom of the sump with neodymiun magnets will do a good job haha
Quote from: Tfsi_Mike on May 16, 2015, 11:58:02 amQuote from: rich83 on May 15, 2015, 01:44:59 pmJust bought some 15x5mm neodymium magnets to make a mag. sump plug... see if it works. Ive had the ECS mag plug fitted for some time. Maybe lining the whole of the bottom of the sump with neodymiun magnets will do a good job hahaDoes the ECS one pick up much stuff??
Made one. Cost about 3 quid
