Author Topic: Smokey exhaust → Replaced valve cover = discovered...  (Read 1250 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« on: May 07, 2015, 07:46:13 am »
I began noticing smoke from the exhaust and I previously did an EVAP reroute but the smoke persisted under heavy boost and again would appear just before coming to a stop when in low gear and coasting to a stop. After removing the old valve cover I noticed cleaning fluid leaking out of the PCV to Rear Breather Route when I sprayed cleaner in that route as well as a poor seal around the larger splash plate...all is noted in the vid.
&feature=youtu.be
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
Re: Smokey exhaust → Replaced valve cover = discovered...
« Reply #1 on: May 07, 2015, 08:41:02 am »
good job for bringing this up - it's been a well known issue in the states for a few years, they seem to suffer more from failed VC then we do. It's always good to raise awareness though  :happy2:
Touran TFSI Quattro | stage 2+ BHZ | UK's first
