Author Topic: New car on Tuesday ....Cited !  (Read 30809 times)
Phil Mcavity
Re: New car on Tuesday ....Cited !
« Reply #120 on: December 13, 2009, 06:17:01 pm »
Pm our horny devil Hedge, as he has all the maps from superchips  :wink:
Offline 182_blue
  • -Receive: 54
« Reply #121 on: December 13, 2009, 07:52:19 pm »
i have now done that and he says that the latest map is the one where the dsg and manual are combined in one map lol, the plot thickens
Phil Mcavity
« Reply #122 on: December 13, 2009, 07:56:50 pm »
really!!  :surprised: so what on earth made my car go do- lally tit with the 1st map i was given. They said to me ive been given the manual map??.
Perhaps Mr Hedge could explain some more??  :popcornsoda:
and is there anyway of finding out which map i have to see if its the latest one?
« Reply #123 on: December 13, 2009, 08:01:08 pm »
It is the VALUES such as requested boost, timing, fuelling, etc that are the same not the actual maps as you and I know Phil but....
If you put a manual map on a DSG car it misfires like a bitch.
Phil Mcavity
« Reply #124 on: December 13, 2009, 08:02:21 pm »
so does my bluefin device tell me what version map i have to confirm its the latest one?
« Reply #125 on: December 13, 2009, 08:04:19 pm »
Not as far as I am aware however should you give Shaun your handset number then Superchips could possibly give him the same map.
However you have had an additional map since then so the possibility for failure is present. :smiley:
Phil Mcavity
« Reply #126 on: December 13, 2009, 08:15:41 pm »
Its the same map that replaced the faulty map, but i will Pm shaun with my handset serial number if he wants it??
Shaun?
Offline 182_blue
  • -Receive: 54
« Reply #127 on: December 13, 2009, 08:38:41 pm »
it sound like you have the map i had before this one, i.e feels better from low down, but the peak power is less (hard to tell from jusr driving)
Offline 182_blue
  • -Receive: 54
« Reply #128 on: December 13, 2009, 08:41:22 pm »
Shaun?
Im guessing not as mine is a manual LOL, your dsg right ?
i think i get this now, although the map is the same map for both, its tailored for manual or DSG
Phil Mcavity
« Reply #129 on: December 13, 2009, 08:43:15 pm »
Shaun?
 :drinking:
Offline djhorace
« Reply #130 on: December 14, 2009, 01:00:51 pm »
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #131 on: December 14, 2009, 01:50:59 pm »
are there not revision numbers to enable you all to follow each Bluefin version map???
I'm lost on previous/old/new/current/manual/dsg map version  :xmassmiley:
Red ED35 5dr DSG
BLOG | BUILD
Offline djhorace
« Reply #132 on: December 14, 2009, 01:57:03 pm »
Aye, well I am unfamiliar with SC and BF, but I have to say I am not altogether blown away by them so far. My view on SC BF before was that its the option to choose if you are worried about warranty as you can remove it completely from the car unlike its competitors. This is still the case as I cant see any other redeeming features thus far.
Offline djhorace
« Reply #133 on: December 14, 2009, 03:22:53 pm »
Can anyone suggest why the throttle position angle would be delayed until approx 4000rpm?
Offline subaru26675
« Reply #134 on: December 14, 2009, 03:33:34 pm »
Here is my reply from SC , could well be right !
Ok, if you look at column D, this is the air flow, there is no air flow until nearly 4,000rpm when it starts to rise, which also follows with Column F with the ignition advance, it shouldn't be getting near to 20 degrees advance until much further up the rev range, even then it would be in the mid teens.  Then when you look at Column E, you see why, it isn't on full throttle until 3880rpm.
As such it look like you have a problem with your throttle.
